a/c not working
Old May 22, 2011 | 10:17 PM
sullivanj04's Avatar
sullivanj04
Default a/c not working
So my ac doesn't work and noticed the compressor clutch is not engaging is there a way to test if its the clutch or somthing electrical
Thanks
Old May 22, 2011 | 11:08 PM
put a jumper wire in the low pressure switch, see if the compressor engages.
Old May 22, 2011 | 11:16 PM
sullivanj04
Thanks for the help oh stupid question but where is the low pressure switch and is there any specific wires to jump
Thanks
Old May 22, 2011 | 11:23 PM
its on the receiver/dryer up by the firewall. only two wires there, stick a jumper between them with the engine running, and my guess is, the compressor will engage. Don't leave it run too long that way, as it indicates the system is low on charge, and therefore, low on lubricant as well.....
Old May 22, 2011 | 11:48 PM
sullivanj04
Awsome thanks
Old May 23, 2011 | 12:10 AM
DodgeRam10's Avatar
DodgeRam10
if that doesnt work, check the fuses including the horn fuse.
Old May 23, 2011 | 12:21 AM
sullivanj04
Could it be a relay or should I just focus on the fuses
Old May 23, 2011 | 12:49 AM
DodgeRam10's Avatar
DodgeRam10
i just had the same problem and what it was is my lower horn was shorting out and blowing the horn fuse, i disconnected the horn and replaced the fuse and it started working. if you suspect its a relay just pull the ac clutch relay and swap it with one of the other relays( pretty sure there all the same but match the numbers)
Old May 23, 2011 | 01:01 AM
sullivanj04
Ill check that out my horn doesn't work so u may be right I hope so I love the stupid simple fixes
Thanks for your help
Old May 23, 2011 | 09:55 AM
DodgeRam10's Avatar
DodgeRam10
thats probably it then, crawl under the drivers side and look just behind the headlight and youll see two horns, disconnect one at a time to see which is bad. Replace fuse and youll compressor will kick on when you put the new fuse in
