hole in ac hose - replacement?
Old May 28, 2011 | 09:36 PM
catalyst's Avatar
catalyst
Default hole in ac hose - replacement?
i have a hole in my ac hose right in the rubber part directly after the fill nipple.
is there any way to repair the hose or a part number for a replacement?
Old May 28, 2011 | 10:53 PM
Should be able to get a replacement hose from just about any parts store. If you want original quality though, gotta go to the dealer. (and pay about twice as much.....)
Old May 29, 2011 | 12:34 AM
catalyst's Avatar
catalyst
yeah but the oem hose is all 1 piece or so it seems and actually has a bracket, 2 hoses, etc.
can i just cut the exiting hose off and splice in a new piece safely? its leaking probably about an inch away from the ferrule.
I'm not really sure what kind of PSI the AC system is under, so I don't want to repair it and risk launching a fitting through my hood or something.
However, I can't really see having to cough up $137 for an OEM hose for an old truck, when the rest of the hose is perfect.
Old May 29, 2011 | 08:18 AM
Novarider's Avatar
Novarider
On the low side it shouldn't go above 50psi correct? You probably COULD get away with splicing it but it might leak. I would replace the hose and be done with it. Do you know how/why the hole got there?
Old May 29, 2011 | 10:33 AM
have a look at the price of R134a...... now, how many of those cans would you have to go thru to pay for a hose that won't leak? So, you can pay for the hose, or, you can pay for refrigerant that will leak out. Your choice.
Old May 29, 2011 | 12:15 PM
catalyst's Avatar
catalyst
i'm not sure how the hole got in there - looks like a slice of some sort, like someone hit it with a blade.
if the system isn't under a ton of pressure, i'd have no objection to putting in a fitting and clamping it down with a hose clamp - I can't imagine that it would leak if done correctly.
if buying a new hose is the only way to fix it, im entirely open to that option - but it sure feels like a lot of waste to junk the entire setup because of 1 bad hose that has a couple of ferrule fittings on it. worst case, you'd think it could be repaired somewhere with a section of new hose.
Old May 29, 2011 | 12:22 PM
You might be able to get away with a splice...... worth a shot anyway. If you have trouble getting it to seal, then you can look at replacing the hose.
Old May 29, 2011 | 12:39 PM
charlie1935's Avatar
charlie1935
It may operate at no more than 50 lbs. pressure but the pressure will go higher when when you turn it off I believe.
Am I right, Hey You?
Old May 29, 2011 | 12:48 PM
I do believe so, the pressure will equalize when the system isn't running. What it finally ends up at, I am not entirely sure. (would be interesting to check though..... might do that when I start working on my A/C again for the summer.....)
Old May 29, 2011 | 01:53 PM
catalyst's Avatar
catalyst
i found a replacement for $70 bucks at rockauto. i will probably just go that route.
i'd still have to think that a hose coupler and some hose clamps would have to hold this without issue. i mean its only basically a hose clamp holding it together from the factory. the only difference is it uses a ferrule that is pressed on.
