my theory. chime in
Old May 30, 2011 | 01:41 AM
dodgeman2289's Avatar
dodgeman2289
Default my theory. chime in
ok so i know transgo makes a shift kit that will make it to where you have to shift it manualy all the time.. my theory is.. wut if somone got that kit and put in a floor shifter.. instead of having a clutch you could basically have a stick shift with no clutch.. sound legit?? i just thought of it after seeing a kit white stage 1 basic, stage 2 hold any gear at any rpm, stage 3 full manual.. feel free to correct me if im wrong but that sounds like it would be sweet. i dont plan on doing it.. just thought it was a great idea.
Old May 30, 2011 | 08:54 AM
Drag racers to that trick. For a truck that is a daily driver, I would still want some automatic function...... maybe i'm just lazy.
Old May 30, 2011 | 08:56 AM
Novarider's Avatar
Novarider
Why have an automatic if you want to shift?
Old May 30, 2011 | 09:27 AM
shorty24v's Avatar
shorty24v
could someone also explain how a shift kit works? This is the first I've heard of one. I did a search but all I'm finding on here is opinions on different brands not what one is and how it works.
Old May 30, 2011 | 10:04 AM
Depending on the kit..... they raise shift points to varying degrees, and firm up the shifts. (the shift itself happens quicker, allowing less slippage between gears, thus generating less heat, and making for a happier trans.) They will also reduce "gear hunting" when you drive at some speed that under normal circumstances, is 'close' to a shift point. (the trans has a hard time deciding what gear it really wants to be in.)
The sonnax sure cure (a flavor of shift kit for our trucks.) does all this, and also smooths TCC operation. Drastically reduces gear hunting, alters the valve body so that you get fluid flow to the torque converter in park, (which our tranny's do NOT do stock, let's ya check fluid in park...) and I think it also improves fluid flow to the O/D unit. A known weak point in the 46RE trans.
Old May 30, 2011 | 02:57 PM
dodgeman2289
so the kit i bought isnt as good as the one you just listed??? also i get mine installed tom morning.
Old May 30, 2011 | 02:58 PM
dodgeman2289
ya i know what you mean.. i dont plan on doing it. i just thought of it and wanted to see if its been done.
Old May 30, 2011 | 04:28 PM
xjarhead69's Avatar
xjarhead69
I have to agree with everything you said but this gives a good discription of what the Sonnax sure cure does for our trucks http://www.sonnax.com/system/announc...C-46-47RHE.pdf.
Its not a shift kit.
Dave
Old May 30, 2011 | 05:14 PM
Dave
It serves a lot of the same purposes.
Old May 30, 2011 | 05:50 PM
xjarhead69's Avatar
xjarhead69
It doent address the shift overlap issue like a shift kit.
http://www.allpar.com/mopar/shift-kits.html.
Taken from the link above:
Shift kits
Steve Knickerbocker wrote that "Smooth shifting transmissions accomplish [smoother shifting] by being in two gears at once when shifting up. It's known as shift overlap. Shift kits reduce or eliminate the shift overlap and speed up actuation of the shift, hence the harder feel to the shift. A shift kit will reduce wear because you won't have the trans trying to be in two gears at once."
Dave
