Transfer case leaking
Old Jun 10, 2011 | 09:17 AM
Annihilator_X9's Avatar
Annihilator_X9
Default Transfer case leaking
Okay people, here's one for ya. I looked at the DIY for the output shaft seals, but mine is leaking from a different spot... right where the housing is bolted together.
What's the prognosis? Tear it out and tear it down?
Old Jun 10, 2011 | 10:42 AM
BamaRam97's Avatar
BamaRam97
Is it leaking ATF or is it leaking gear oil? That is the low spot on the transfer case and most any leaks run to that spot.
Old Jun 10, 2011 | 11:27 AM
Annihilator_X9
I noticed it last night after dark. I'll take another look today and see where it's actually coming from.
Old Jun 10, 2011 | 12:10 PM
aim4squirrels's Avatar
aim4squirrels
You can actually use ATF+4 in the transfer case. Actually I recommend that, because if the seal between the t case and transmission were ever to fail, you don't pollute the transmission with gear oil.
Old Jun 10, 2011 | 12:24 PM
BigRedRam95's Avatar
BigRedRam95
Does anyone know where i can get a t case saver for mine? I also need to replace the seals it looks like mine are leaking a bit after the yoak got shoved all the way up into the t-case when i dropped the shaft.
Old Jun 10, 2011 | 12:33 PM
BamaRam97's Avatar
BamaRam97
Here is the link to the Transfer Case Saver.
http://www.drivetrain.com/parts_cata...ase_saver.html
Old Jun 10, 2011 | 12:43 PM
BigRedRam95
one more question when the yoak got pushed all the way up into the tcase could it have messed up anything that I would not know yet.
Old Jun 10, 2011 | 01:00 PM
How did it get pushed up in there? Did you use your driveshaft in an attempt to pole vault with your truck? If you just stuffed it in there by hand, you didn't do any damage. If the weight of the truck was stuffing it in there..... that may be a problem.
Old Jun 10, 2011 | 01:07 PM
BamaRam97's Avatar
BamaRam97
In a normal case, the only thing that I can think of that would shove the driveshaft in there far enough and hard enough is if the rear U joint broke and the shaft slammed in the ground was shoved into the transfer case. Of course for this to happen, you would have to be moving in reverse relatively quickly when the shaft broke.
Old Jun 10, 2011 | 01:11 PM
Annihilator_X9
If I remember correctly, BRR95 was going down the road, so I doubt it would have.
