problem with spark plugs
Old Jun 10, 2011 | 08:26 PM
king_moaoe's Avatar
king_moaoe
Default problem with spark plugs
i was changing my spark plugs when i sliced my arm and dropped the wires that go to the top, i may have mixed 2 of my leads up. im not sure if i placed them on correctly. starts great but sounds different, could that be a cause. new at this so any help you could tell me. only two could be mixed. sorry i have a 1996 dodge ram 1500. 5.9l
Old Jun 10, 2011 | 08:28 PM
Firing order is 1 8 4 3 6 5 7 2. Number 1 is marked on the distributor cap, and it rotates clockwise. Check all the wires....... I know its a major pain....... but, make sure they are all correct.
Old Jun 10, 2011 | 08:37 PM
king_moaoe's Avatar
king_moaoe
where does one start on the block? which side is one and how does the order go.
Old Jun 10, 2011 | 08:56 PM
Drivers side is, front to back: 1 3 5 7
Passenger side, front to back: 2 4 6 8
When I goofed on firing order, it was easier to just take all the wires off the cap, start with number one, and work my way around the firing order.
Old Jun 11, 2011 | 12:09 AM
CPTAFW163's Avatar
CPTAFW163
I put them in backwards once. You really know you are wrong because the wire ends will not fit flat on the distributor.
HOWEVER, your problem could be that you have a loose connection on the distributor or a spark plug. That would be a one cylinder MISS and it would not be very noticeable at idle. But you will notice when driving.
Check to make sure that you have the boot over the plug and it is locked in. I always give a bit of a tug to make sure.
Old Jun 11, 2011 | 05:46 AM
redneck_ram's Avatar
redneck_ram
Here ya go!
