Speedometer jumps like crazy!!
Old Jun 14, 2011 | 09:55 AM
johnnyrocket5363's Avatar
johnnyrocket5363
Default Speedometer jumps like crazy!!
My 99 is giving me a hard time! A few months ago, I started having problems with my speedometer going out. It would show the speed, then flop over to zero, then pop back. I didn't drive it much then, so it was no big deal. But now I've had to put my other truck up to work on it, and it is driving me crazy! I replaced the rear speed sensor (it's a manual, so I only have one), and got no change. I inspected the harness from the frame to the axle, and nothing was bad. I cleaned the harness coupling by the driver side front tire, but still I had problems. By this time, it had gotten worse. Now, it jumps around wildly, pegging out at buth ends periodically. Then I tried unplugging and cleaning the data bus that feeds from the PDC. Finally, I even unplugged the sensor, tied up the harness, and drove it like that. The needle still jumped!! It always seems to coincide with a bump in the road. For a while, I could alleviate the symptoms by running off the road a little. This would jar it into working again for a while. I noticed after jumpstarting a backhoe, my brother shut the hood and the needle jumped. I had him do it again, and the needle jumped again. I will not pretend this thing has never seen mud, and just a short while ago my relays went bad, apparenty due to off-roading. Any thoughts?? Thanks!!
Old Jun 14, 2011 | 10:01 AM
You have a bad connection somewhere. Trace all wires responsible for speedo, clean all connections. See if that doesn't help.
Old Jun 14, 2011 | 10:25 AM
johnnyrocket5363
What haven't I checked? The only thing I can imagine is the PCM it's self... And whats the best thing to use to clean and prevent?
Old Jun 14, 2011 | 10:29 AM
PCM gets its signal from the sensor, and then tells the cluster what speed to read.... (via the CTM I think). Not exactly the best design in the world...... There is just a boatload of 'stuff' between the sensor, and the speedo.
Old Jun 14, 2011 | 12:09 PM
johnnyrocket5363
Can you reccomend a method to clean the connectors? I tried electrical parts cleaner and dielectric grease...
Old Jun 14, 2011 | 12:51 PM
I use brake cleaner, and a tiny little wire brush....... I have no idea where the brush came from......
Old Jun 15, 2011 | 07:51 PM
johnnyrocket5363
Alright, I think I fixed it. I pulled the battery, then removed the PCM connectors. I sprayed them with contact cleaner, replaced them, removed them again, sprayed again and coated the sockets with dielectric grease. It worked all day!! Thanks!!
Old Jun 17, 2011 | 08:59 AM
johnnyrocket5363
Default Shock problems. and should I go with a lft kit, or 2500 springs?
Thanks!!
Old Jun 17, 2011 | 10:54 AM
Awesome! Glad ya got it working.
