95 1500 nv3500 problem...
Old Jun 14, 2011 | 04:26 PM
scott1975's Avatar
scott1975
Default 95 1500 nv3500 problem...
My 2WD 99 Ram 1500 also has an NV 3500, not sure what lube was in there but it died. 4th gear was the only one working. ?!?!?! any ideas out there? thanks for the help ahead of time.
Old Jun 14, 2011 | 08:23 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
Before anything else, I recommend reading this post here.
I will move this one to the 2nd Gen Rams for you.
Old Jun 14, 2011 | 11:44 PM
Time for another trans?
Old Jun 15, 2011 | 12:32 AM
matt72991's Avatar
matt72991
u didnt break a shift fork did you? will it go to any other gear? or what happens?
Old Jun 15, 2011 | 07:30 AM
scott1975's Avatar
scott1975
It fills like it will go through all the gears just fine, but when you let the clutch out 4'th is the only gear that pulls.
Old Jun 15, 2011 | 12:30 PM
Hahns5.2's Avatar
Hahns5.2
4th is direct and power goes straight through the mainshaft. All the other gears use the countershaft.
