How would you attack this snapped off bolt?
Old Jun 18, 2011 | 10:42 PM
Mudshack's Avatar
Mudshack
Default How would you attack this snapped off bolt?
So I go to take the intake manifold off and the first bolt I touch snapped off when I sneezed! It most have been rusted nearly completely through. I have already soaked the thing for a few hours with PB Blaster and tried locking vise grips on it. Any other suggestions?
Old Jun 18, 2011 | 10:49 PM
lastrights's Avatar
lastrights
i drilled threw mine since it just comes out the bottom and hooked a bolt to the bottom when i put on my new intake manifold .. i tried other stuff and it didnt wanna come out .. i still have a broken bolt in the back that i discovered taking it off,so i know someone tried to tackle the plenum before me. the bolt didnt even had a head on it
Old Jun 18, 2011 | 11:03 PM
TruckinDodge's Avatar
TruckinDodge
PB Blaster soak over night and heat in the morning with Vise grips on it as tight as I can get it, also try tapping it with a hammer to vibrate some of the rust loose. I had the same problem, same bolt on mine the first time I did mine, it took me a while to get it but it did come out.
Old Jun 18, 2011 | 11:08 PM
dhvaughan's Avatar
dhvaughan
if you have a welder, you could weld a nut onto the top of the broken bolt, then apply a wrench to the nut, combined with penetrating oil and heat.
and/or i'd try a plumber's propane torch, applying heat to the bolt, then try to turn it with the welded nut or vice grips.
also, if you don't have a welder, but do have a die set, you could attempt to cut/fix new threads on the broken bolt, then thread on a couple of nuts and lock them together.
heat's going to be your best friend. it stretches the bolt and breaks the rust lock.
Old Jun 18, 2011 | 11:09 PM
Sheriff420's Avatar
Sheriff420
An RPG?
Old Jun 18, 2011 | 11:11 PM
SilverSS's Avatar
SilverSS
I've actually had really good luck with these things. Might be worth a shot. http://www.craftsman.com/shc/s/p_101...yword=bolt+off
Welding a nut to it would be the easiest if you have a welder. Anybody ever tried that with JB Weld?
Old Jun 18, 2011 | 11:17 PM
dhvaughan's Avatar
dhvaughan
jb weld is good, but not that good. the torque would break it right off.
Old Jun 18, 2011 | 11:33 PM
Chemicals, heat if ya got it, vice grips, and rapping on it with a hammer while trying to turn it works rather well. (as said above. )
I drilled thru mine, and then blew the rest out with a torch. Ran a tap down the holes, and all was well in intakeland.
Old Jun 19, 2011 | 12:06 AM
CraZyNOTRT's Avatar
CraZyNOTRT
well if you didnt destroy all of the threads on it i would have told you to get 2 nuts and screw them on, back the 2 nuts together and back it out.
but the best thing to do now is grind it in to a square and put a socket on it and take it out, or get a socket that smaller then the bolt and hammer it on, or jbweld a nut
Old Jun 19, 2011 | 12:33 AM
Sheriff420's Avatar
Sheriff420
I did something similar on a couple exhaust manifold bolts on my Camaro. I just ground two flats on them and used vise grips since they're 5/16" bolts.
Two nuts is a good one too, just crank on the bottom nut and it would lock together with the top one.
