best intake manifold upgrade
Old Jun 18, 2011 | 11:20 PM
Buck Slayer's Avatar
Buck Slayer
Default best intake manifold upgrade
Hey guys so my question is, on a 318 as far as the intake manifold goes. What is/who makes a good aftermarket upgrade?
Old Jun 18, 2011 | 11:30 PM
Only two choices really, and they are basically the same manifold.... Hughes Air Gap, and the edelbrock of the same design. Ma Mopar also makes a single plane manifold, but, "best" depends on what you want to do with your truck.
Old Jun 18, 2011 | 11:52 PM
Buck Slayer
well im looking mostly for low to mid range power. but mostly low.
Old Jun 19, 2011 | 12:13 AM
Adobedude's Avatar
Adobedude
Then stick with the stock kegger.
Old Jun 19, 2011 | 12:24 AM
Buck Slayer
so it won't benfit me any? if i went with aftermarket would i keep my low and add top end?
Old Jun 19, 2011 | 12:35 AM
Adobedude's Avatar
Adobedude
It's a sum of parts...What other mods do you have?
I'd spend money on the exhaust side for cheap low end. Dodge spent some time on the kegger, it's for a truck motor.
Old Jun 19, 2011 | 12:59 AM
lastrights's Avatar
lastrights
i love my airgap one of my fav mods alone with the sct tuner def woke my truck up .. passing people takes no effort at all
Old Jun 19, 2011 | 01:01 AM
JSTMoto's Avatar
JSTMoto
Im not saying that the aftermarket intakes aren't an option, but I'll agree with Adobedude.
The stock Kegger is already pretty decent at low to mid range torque. The long intake runners of the Kegger are what help in this department (which is why it's in the shape of a 'keg' to begin with).
Think: High Velocity of flow, NOT High flow.
If you want low end torque, I'd spend your money elsewhere and leave the Kegger on there. A FULL tune-up would be my first move (Cap, Rotor, Plugs, Plug wires, and timing chain). Then maybe some 1.7 RR's.
I'd also look into a better torque converter if you're serious. These stock torque converters are junk. My sister had an 05 Toyota 4runner, and you really had to push on the brakes to keep it from moving AT IDLE! I'd get in it and start it, get my foot on the brake as usual, put it in gear, and it would start moving! Quite the surprise.. Felt like it had gobs of low end torque (it was Sport, with a 4.7l v8 with 270hp, 320ft-lbs). I was impressed with it's stock torque converter for sure. It had less torque, but it sure could put it to the ground a heck of a lot better than my Ram can.
-JT
Old Jun 19, 2011 | 01:06 AM
DodgeTheDadRamTheDaughter's Avatar
im not disappointed with the Huges Air Gap but its not like your going to get crazy power with it alone, and i don't personally feel there was any significant loss of low end power. I recently pulled my flatbed trailer loaded with my 200lb tool box and a jeep wrangler on it with some gear and guys in the truck and it moved it without any problems. The engines cam is what is going to determine where your engine can make its power but thats not to say the air flow isn't going to change the curve of the band a little bit around your rpm range. (I was mainly only wanting low to mid range power to)
Old Jun 19, 2011 | 12:45 PM
Buck Slayer
-JT
Yea, I just did a tune up about 1k miles ago, everything but the timing chain. And the 1.7 rr are coming in the near near future. Also this summer ill be supercharging it and going with a full exhaust and long tubes. (If I can find them for our truck). I've thought about a torque converter before but what kind of stall should I be looking for and how difficult is the install?
