Power seat controls falling out
Old Jun 19, 2011 | 08:35 PM
idahoprime's Avatar
idahoprime
Default Power seat controls falling out
Hey, so i just got this 97 Ram 1500 and the power seat controls are kinda hanging off the seat a little bit. It still works and everything and it didnt bother me too much at the time. Well, ive been noticing that sometimes after the door is closed and i lean a certain way, the controls touch the side of the door and my seat actually moves. Freaked me out for a minute til i figured out what was going on. Has anyone ever taken these things apart or had a similar problem? The screws are still there, and it seems to be screwed into something, so im thinking that that something has maybe broken loose inside the seat? I dont really know what i should do next, other than rip into the uphostery, can anybody tell me whats going on under there beneath my uphostery? Any suggestions on getting this thing back in its place? Heres a pic, thanks.
Old Jun 19, 2011 | 10:52 PM
See if you can see anything from underneath the seat. might be as easy as putting in slightly larger screws.
Old Jun 19, 2011 | 11:02 PM
aim4squirrels's Avatar
aim4squirrels
If the wooden mounting panel is torn to hell and back, or fell out and is gone missing, try another wood panel or even a metal plate and some small machine bolts or self tapping screws. Might even be a dealership part they can order that is a direct fit. I'm pretty sure it's a thin wood panel that is in the upholstery.
Old Jul 3, 2011 | 10:42 PM
idahoprime's Avatar
idahoprime
Got this fixed and forgot to report back. There is no wooden mounting panel (at least not in mine). My controls, and the foam & the hole in the seat cover were ALL out of allignment, my guess is that it has been like that for a while and from people sitting in the seat everything just got moved around. Anyway, after cutting the seat cover just a little I was able to get it all back in. There are just 2 screw holes in the actual seat frame, you just have to be lucky enough to get them lines up. I have no idea how mine came out, the screws were still in the controls and through the seat cover. They didnt look stripped and they went right back into the seat frame. Weird.
