Old Aug 6, 2015, 11:45 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Weird ABS/Airbag/Check Engine light problem?
Old Jun 22, 2011 | 06:55 PM
Novarider's Avatar
Novarider
Nothing different at all. No chargers or anything. I checked with the auto parts stores and their scanners don't read code histories.
Old Jun 23, 2011 | 09:40 AM
Gonna have to find an independent shop, that will plug it in for ya cheap.
Old Jun 26, 2011 | 03:38 PM
Novarider's Avatar
Novarider
Now when my fog lights are turned on the brake light is barely lit up it barely glows. Is that a symptom of the speed sensor also? My brakes aren't dragging it coasts like normal.
Old Jun 26, 2011 | 03:57 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Remove the headlight switch and check it and the plug. Also, remove the covers from the steering column and check that harness.
Old Jun 26, 2011 | 06:40 PM
Novarider's Avatar
Novarider
This just started when I had the ABS light come on then go off. If I turn the fog lights off the brake light turns off fully but when the fog lights are on the brake light just barely glows.
Old Jun 27, 2011 | 11:08 AM
Novarider's Avatar
Novarider
How do I remove the sensor? I have the bolt off and the wiring clip off but can't get the sensor out. It spins pretty easily but I can't get it to pull out.
Old Jun 27, 2011 | 11:18 AM
BamaRam97's Avatar
BamaRam97
There are two nuts on the ABS sensor on the rear Diff. The first one holds the lines and cables on and the second one, which is formed into the sensor, holds the sensor on. All you have to do is unscrew it.
Old Jun 27, 2011 | 11:22 AM
Novarider's Avatar
Novarider
I have unscrewed it. The sensor will spin freely but I can't get it out. I tried prying in it a little bit but I don't want to break it and something fall into the diff.
Does the sensor itself screw in or pop in?
Old Jun 27, 2011 | 11:39 AM
BamaRam97's Avatar
BamaRam97
Sorry, reading comprehension is tough on Monday. The sensor should just pop out if you have it unscrewed. Try some light prying with very little force from a flathead screwdriver or anything you can get under the lip. There isn't anything to fall into the diff. The other side of the sensor is just a nub.
Old Jun 27, 2011 | 12:48 PM
1&2genrams's Avatar
1&2genrams
it has an o-ring to keep the oil in...it can be a little tight
