Old 08-06-2015, 11:45 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Weird ABS/Airbag/Check Engine light problem?
Old 06-27-2011, 05:07 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Grab it and wiggle it back and forth while pulling on it.
  #22
Old 07-10-2011, 04:10 PM
Novarider's Avatar
Novarider
Novarider is offline
Ok guys I'm having the same problem but it got worse. Now all the warning lights come on and all of the gauges stop working and I get a no bus message where the mileage is . This will happen then will go away a few minutes later. I didn't get the speed sensor changed because I got sick the day I was changing it with food poisoning.
Its all of that related to the rear speed sensor?
  #23
Old 07-10-2011, 04:15 PM
zman17's Avatar
zman17
zman17 is offline
No....
I if you don't have a ground wire problem some where, I'd say the PCM is shot.
  #24
Old 07-10-2011, 05:48 PM
Novarider's Avatar
Novarider
Won't a pcm throw a code when it goes bad? I took it to advance and there are no codes at all. I think I'm going to have to take it to my mechanic tomorrow
  #25
Old 07-10-2011, 05:56 PM
zman17's Avatar
zman17
zman17 is offline
Usually, but like I said, could be a bad ground ,dirty connector or damaged wire. As long as you trust the mechanic and don't get ripped off. Hooking it up to a good scanner by your mechanic is probably your best option right now.
Quick Reply: Weird ABS/Airbag/Check Engine light problem?
