How to find #1 tdc compression
Old Jun 25, 2011 | 12:19 PM
kikidbird's Avatar
kikidbird
Default How to find #1 tdc compression
I believe I installed my cam wrong. I think I set it #1 TDC exhaust and thats why I dont get compression. How do I find #1 TDC compression with the timing chain off?
Old Jun 25, 2011 | 01:04 PM
stick a pencil into the number one spark plug hole, turn the crank till the pencil starts to move a little bit, then, hold the pencil against the piston top, turn the crank slowly till you find the point where it starts going down.
Make sure you distributor is pointed at number one, and both valves on number one are closed. See how your dots on the timing gears line up.
Old Jun 25, 2011 | 02:57 PM
Adobedude's Avatar
Adobedude
I couldn't find a pencil, had to do it like this.
Old Jun 25, 2011 | 03:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
http://www.bionicdodge.com/Download/...uel%20Sync.pdf
Old Jun 26, 2011 | 01:13 AM
kikidbird's Avatar
kikidbird
My timing marks are off. Somehow I screwed up the degreeing cam process.
