Looks like im gonna have to get this sorted, I have noticed that its using quite a bit of oil. I imagine its going to be a nightmare to get in the UK but it'll be worth it!
The idea behind the PCV system is twofold. First, it evacuates all those nasty byproducts of combustion that make it past the rings from the crank case, which helps your oil last longer. Second, by drawing a light vacuum in the crank case, it actually helps the rings seal better, so you get less of the nasty blowbyproducts into the crank case in the first place. Not to mention the side benefit of less wasted power from the better ring seal.
I bet you were the teacher's pet when you were in school.
Actually, I was one of the people your parents warned you to stay away from in High School..... wasn't until college in my adult years that I actually figgered it out.
LOL, you still have the black leather biker jackets? I do.
Just wondering I have a 2004 Durango with 4.7 changed the manifold gaskets and broke the vacuum thing that is at the oil fill anyone know what its called ?
Not sure, but a photo would help. Also, welcome to DF.
You may not realize, this section is 2nd Generation Rams. Only up to 2001. Posting in Dakota section is where you need to be. Not that we mind you haning out here!
You may not realize, this section is 2nd Generation Rams. Only up to 2001. Posting in Durango section is where you need to be. Not that we mind you haning out here!
