Oil Breather Filter Help!?
Old Jun 27, 2011 | 03:10 PM
Bobley's Avatar
Bobley
Default Oil Breather Filter Help!?
Hey guys,
Iv just purchased a ram indy500 and im lookin to get a service however someone has siliconed the oil breather filters on. First of all id like to know if i can just pull this of without causing any damage, and second does anyone know what diameter the breather fitment is?
Can anyone help?
Thanks
Old Jun 27, 2011 | 04:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You have a PCV valve and a PCV elbow, no breathers on the stock system. The rubber grommets are available at most parts stores. Do you have something on there other than the stock setup?
Old Jun 27, 2011 | 05:10 PM
Hahns5.2's Avatar
Hahns5.2
He said right in his post that someone siliconed aftermarket breathers into the valve covers...
Yes you can pull them out. You will want to run a PCV on one side and a breather on the other.
Old Jun 27, 2011 | 05:20 PM
zman17's Avatar
zman17
I see that, just trying to clarify there bud.
Old Jun 27, 2011 | 08:43 PM
Joey Buentello's Avatar
Joey Buentello
I 've been having aftermarket breather problems also. Trying to fit an autozone type breather to my Mopar valve covers. I ordered the gromett kit and the damed thing didn't fit. I think silicone is my only answer. Stock covers have a pcv valve and a plug on the passengers side. A breather and an oil filler cap on the drivers side.
Old Jun 28, 2011 | 09:48 AM
Bobley's Avatar
Bobley
Hi guys, thanks for the help, its running an after marker mopar (top mounted) air filter at the minute with 2 K&N oil breather filters on the Mopar valve covers (one on each side).
I was just going to replace the two K&N oil breather filters with two new ones, as there certainly isnt any PCV valves here.
Anyone know the size of the fitments? Its dificult getting parts over to the UK so I'm simply looking at buying a universal filter that will fit.
Old Jun 28, 2011 | 10:04 AM
BamaRam97's Avatar
BamaRam97
You are really going to want to put a PCV valve in there. On your truck it should be in the passenger side valve cover.
Old Jun 28, 2011 | 10:56 AM
99dodge318's Avatar
99dodge318
different years had the pcv valve on different sides, also the air boxs are slightly different.
Old Jun 28, 2011 | 05:48 PM
Bobley's Avatar
Bobley
Mine certainly hasnt got a pcv on any side at the minute, just two breather filters.... why would i need to put one on? its been running fine so far. Probably a stupid question but im not a mechanic!
Old Jun 28, 2011 | 06:21 PM
The idea behind the PCV system is twofold. First, it evacuates all those nasty byproducts of combustion that make it past the rings from the crank case, which helps your oil last longer. Second, by drawing a light vacuum in the crank case, it actually helps the rings seal better, so you get less of the nasty blowbyproducts into the crank case in the first place. Not to mention the side benefit of less wasted power from the better ring seal.
