bad sound coming from front mainly when turning right
wow you are awesome. thanks so much. Now I just looked at this wheel bearing replacement and it looks real easy. for the guys on here that have done this before it looks like all i do it jack the truck, pull the tire off, take the caliper off the rotor, pull the rotor off, then losen a nut that then the hub/wheel bearing (I'm guessins this is all one peace) pulls off. I just replace the hub/wheel bearing and then put the rotor back on, bolt the caliper back on, put the wheel back on and im done.
Oooo, not THAT is a nifty tool. Wonder if it would work on dodge axles.
Harbor Freight sells a nice piece of chrome plated garbage that's supposed to be similar. I know someone who bought the HF tool and (surprise) it broke when he tried it.
The Torque-Meister fits 36mm axle nuts and at 30-ft/lbs on the torque wrench = 270-ft/lbs output. I'm betting an industrious individual could figure a way to make an adapter so it could fit the Dodge setup provided the axle nut on the Dodge is 36mm.
Trust me, I've removed the most stubborn axle nuts using this tool with minimal effort.
