2000 ram blown starter sol fuse
Old Jun 28, 2011 | 08:49 PM
efd704's Avatar
efd704
Angry 2000 ram blown starter sol fuse
I have a 2000 dodge ram 1500 that keps blowing starter sol fuse when trying to start it. I unplugged starter and it doesnt blow. Had starter tested and they said it was good but all they tested was to see if it ran. Any Ideas on what to do
Old Jun 28, 2011 | 11:38 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. First, before anything else, please read this.
I will move this to the 2nd gen section for you.
Old Jun 28, 2011 | 11:41 PM
How did they test it?
Is the fuse the right size?
Old Jun 29, 2011 | 08:09 PM
efd704's Avatar
efd704
They pretty much just hooked a hot and a groung to it and said yep it turns. And yes it is the fuse it calls for a 20 amp. Also if you unhook the starter it does not blow.
Old Jun 29, 2011 | 08:14 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I guess the starter is no good then.
Old Jun 29, 2011 | 08:17 PM
efd704's Avatar
efd704
Could it still turn and be bad. And could it be anything else blowing the fuse.
Old Jun 30, 2011 | 07:48 AM
Novarider's Avatar
Novarider
Maybe a short?
Old Jun 30, 2011 | 08:08 AM
zman17's Avatar
zman17
It is possible for it to free spin and seem good, but once the extra load of the motor is on it, it fails. I'd hate to see you spend money for nothing, so make sure wires/cable check out good first.
Old Jun 30, 2011 | 09:07 PM
efd704's Avatar
efd704
Smile fixed
Finally found the problem. The hot wire going from battery to starter was coreoded in side had to cut back to good spot.
Old Jun 30, 2011 | 09:09 PM
zman17's Avatar
zman17
Good job man,
