Mechanic in Sacramento, CA
Old Jun 29, 2011 | 08:09 PM
Cheesehead's Avatar
Cheesehead
Was kinda thinkin same thing
Old Jun 29, 2011 | 08:19 PM
Awful coincidental that it blew while they had it though.... but, not like it is something they could have done on purpose....... Unless they overheated the engine nicely for you.....
Old Jun 29, 2011 | 08:26 PM
ShelbyGT550's Avatar
ShelbyGT550
I wouldn't think it would just let go though? Might be wrong though.
Old Jun 29, 2011 | 10:48 PM
Cheesehead's Avatar
Cheesehead
Going to check the milage out in the morning. Whats the next steps
Old Jun 29, 2011 | 10:49 PM
Pressure test the cooling system with the spark plugs out. Roll the engine over slowly while you have pressure on the system, and see if water comes out anywhere.
Old Jul 1, 2011 | 11:19 AM
Cheesehead's Avatar
Cheesehead
Don't have any way to pressure test the cooling system but I checked the oil again clean and in the safe zone. Antifreeze full.
I started it again and there was smoke coming out of the exhaust but no where near as bad as when I got to Les Schwab. I didn't push the issue too much. No weird noises or anything in the motor while idling.
I have been reading the plenum sticky and was wondering if these symptoms are in line with that type of issue. I have had that hard knock sound on occasion. Especially if I slow down very fast and then go to accelerate again. If I back out of it for awhile things get back to normal. I also go thru oil pretty regularly.
I will try and look and see if there is oil pooling.
Old Jul 1, 2011 | 11:29 AM
The oil consumption is a pretty sure sign of a blown plenum....
If you let the truck run for abit, does the smoke clear up??
Old Jul 1, 2011 | 11:37 AM
J415's Avatar
J415
Originally Posted by Cheesehead
Don't have any way to pressure test the cooling system...
Go to Oriely's and rent a pressure tester.
Old Jul 1, 2011 | 11:42 AM
Cheesehead's Avatar
Cheesehead
At work now so I will try that and let you know. Anything else I should check?
