Smart Buys
Old Jun 29, 2011 | 09:44 PM
byronpen's Avatar
byronpen
Default Smart Buys
Ive manege to save 1000.00.... what are the smart buys for the must power as in upgrades.
Old Jun 29, 2011 | 10:41 PM
If the plenum isn't fixed yet. Do that.
SCT tuner.
1.7 roller rockers.
headers
performance y pipe.
That should wake things up for ya.
Old Jun 29, 2011 | 10:58 PM
J415's Avatar
J415
If you've managed to save $1,000 and are looking to spend it, definitely do the plenum fix and the timing chain. Other then that, save it for when the truck breaks down on you so you can fix it...because it will when you don't want it to.
Old Jun 29, 2011 | 11:04 PM
Yeah, I always seem to forget that doing my timing chain and gears was probably the most effective 'performance mod' I have done to my truck...... The difference was amazing.
Old Jun 29, 2011 | 11:25 PM
Ramzy's Avatar
Ramzy
I couldn't believe the difference it made when I did mine either. Would never have guessed it could make that much of a difference.
Old Jun 30, 2011 | 12:02 AM
Adobedude's Avatar
Adobedude
Really...
Is the stock timing chain that sloppy? I have a spare double roller, maybe I should put it on the 98 Ram, but it has less than 90K on it. Problem with me is if I do a chain, I figure just a few more bolts and I have heads and a cam....
Old Jun 30, 2011 | 12:22 AM
J415's Avatar
J415
It starts off so innocently with just a couple of bolts...I suffer from that same illness and I'm NOT looking to be cured of it!
Old Jun 30, 2011 | 07:33 AM
Novarider's Avatar
Novarider
Did you guys use the timing chain from the parts store? Did you use the kind that has a chain or the kind that has 2 big gears and 2 small gears instead of a chain?
Old Jun 30, 2011 | 09:17 AM
95BIGRED's Avatar
95BIGRED
i got a double roller set at oreily's for cheaper than the stock set. been about a week now and seems to be holding up really well.
Old Jun 30, 2011 | 09:36 AM
I picked up the SA something or other .25 inch double roller from advance. It was under 50 bucks. Went right on, and looked to be a quality part. I had 165000 miles on the original, and it was stretched pretty good. (morse style chain.)
