plenum plate dimensions
Old Jul 2, 2011 | 05:02 PM
80omni's Avatar
80omni
Default plenum plate dimensions
im thinking of making my own plate but am unsure of the dimensions, if anyone has an old steel plenum plate lying aroun could you measure it out as a rectangle so i know what size plate to buy,
Thanks
Old Jul 3, 2011 | 01:12 PM
80omni's Avatar
80omni
anyone?
Old Jul 3, 2011 | 01:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
IIRC 10 x 17.
Old Jul 3, 2011 | 01:27 PM
S S0DEN's Avatar
S S0DEN
The stock plate is offset, I have a couple lying around if you want a picture.
Old Jul 3, 2011 | 01:32 PM
zman17's Avatar
zman17
He wants the size plate (squared) you would need to make one. Not a picture.
Old Jul 3, 2011 | 01:37 PM
80omni's Avatar
80omni
yes i would like to know what size plate i need to buy. i only have 8 inch wide at home, so if i need 10 wide i have to buy it.
also, would 1/8 inch work?
Old Jul 3, 2011 | 05:42 PM
zman17's Avatar
zman17
I'd use 1/4" if making it out of aluminum.
Old Jul 3, 2011 | 06:51 PM
redheadhunter21's Avatar
redheadhunter21
If you pick up the gasket, you can use that to cut the plate out, and I also second using a 1/4 piece of aluminum, it will keep the plate from warping
Old Jul 3, 2011 | 06:55 PM
zman17's Avatar
zman17
Damn, that's one awesome gasket.
