Needing help with A/C diagnosis
Old Jul 4, 2011 | 03:49 PM
jdbrown12's Avatar
jdbrown12
Question Needing help with A/C diagnosis
2000 Ram 1500 5.9L 2WD 158K miles
System was working fine, then 1 day it wasnt.
- A/C condenser is new in the past year
- Low line tests at 40 psi (its 88 here today)
- dont have a guage for high line.
- jumped connectors for high and low line pressure switches and doing so doesnt change anything.
- compressor will kick on for 3-5 seconds then kick off for 5-10 seconds
- cold line is cold, hot line is hot
- horn works
What am I looking at, bad compressor?
its my first rodeo with A/C so I am a little frustrated at this point, any help is greatly appreciated. thanks
- JD
Old Jul 4, 2011 | 04:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Sounds like it's low on 134a to me.
Old Jul 4, 2011 | 04:21 PM
jdbrown12's Avatar
jdbrown12
what should my pressure be? I was under the impression it was good between 35-50.
Old Jul 4, 2011 | 04:46 PM
zman17's Avatar
zman17
What gauge are you using? The thing that comes with a can? Before I got the right equipment, I filled it until the air blew nice and cold, and the compressor didn't cycle constantly.
Old Jul 4, 2011 | 07:24 PM
There should be a chart on the can, that tells optimal pressure vs. ambient temp.
Old Jul 4, 2011 | 07:31 PM
zman17's Avatar
zman17
He's right on with the pressure, but if it's one of the cheap gauges on a can, I wouldn't trust it.
Old Jul 5, 2011 | 06:42 PM
jdbrown12's Avatar
jdbrown12
I was checking with the gauge that comes on the can of 134a. Went and got a set of A/C guages from the auto store loaner tool program. still tests at 40 psi, 87 degrees today.
Old Jul 5, 2011 | 06:47 PM
zman17's Avatar
zman17
It still does not mean there is the correct amount of 134a in it.
Old Jul 5, 2011 | 07:09 PM
Is that 40 pounds while the compressor is running?
Old Jul 5, 2011 | 07:18 PM
zman17's Avatar
zman17
When the horn honks, lol
