Speed Sensor
Old Jul 5, 2011 | 12:51 PM
Raminator2001's Avatar
Raminator2001
Default Speed Sensor
Hello im at the end of my auto to man swap. i have a 3 pin speed sensor in the transfer case on the manual (NV3500) with a geardrive unit , but the automatic harness only has a 2 pin connector (non Gear driven). autozone dosent show anything for the manual sensor pic below is the autozone automatic listing Dorman/Sensor - Transmission Speed
For your 2001 Dodge Truck RAM 1500 1/2 ton 4WD 5.2L SFI 8cyl
Part Number: 917-602,
here is a link to the type of sensor i have in the manual,
http://cgi.ebay.com/ebaymotors/Airte...mZ320697976962
Old Jul 5, 2011 | 03:39 PM
What year truck was the transfer case out of?
Any chance of swapping the manual trans input stuff into the other t-case?
Old Jul 6, 2011 | 12:28 AM
Raminator2001
thats exactly what i did heyyou,the manual transfer case is a 94 with the speed sensor being the 3 prong,my automatic t-case had no plug (autos had speed sensor in the transmission) my manual case had a crack,so i swapped out the internals into the auto case & used the manual tail housing to support the speedometer. my guess is that this sensor only used for the odometer/speedometer
Old Jul 6, 2011 | 01:17 AM
Hahns5.2's Avatar
Hahns5.2
The PCM also uses the sensor to control idle speed based on vehicle speed. At least in a stock configuration with a manual trans.
Old Jul 11, 2011 | 12:10 PM
Raminator2001
ok lots of research has payed off,speedometer would not work with just the differential ABS/Speed sensor,here is what i have came up with for the output speed sensor located in either the trans or transfer case.
PCM connector C2 (white) 32 pin connection
94-97 (3 pin) in transfer case
Pin #1 white/orange stripe:SIGNAL (terminal 27@ PCM )
Pin #2 Black/L Blue stripe:GROUND (terminal 4@ PCM )
Pin #3 Orange:+5 Volts (terminal 31@ PCM )
NOTE: Pin 2 and 3 wires can be found on solinoid plug on A/T(round multi plug)
98- ? (2 pin) located in A/T
Pin #1 D Blue/Black Stripe:GROUND (terminal 25@ PCM )
Pin #2 L Green/Black Stripe:SIGNAL (terminal 28 @ PCM)
i spent alot of time on these,hopefully someone can use this info also.
