New Muffler/Exhaust System
Hey Y'all. I got a 99 dodge ram 1500 with a 360 magnum and I've been looking to get a new muffler for sound (and maybe a SMALL mpg boost). I've looked at some cheaper kits (I'm pretty broke), but I wondered if I could take a cheaper route. If I just bought a muffler, could I cut off the stock muffler, install the aftermarket one, and use all the stock piping thats there? I would have to clamp it on, and I know I can dump the exhaust right after the muffler, but I would prefer to use the stock piping before ( from the cat) and after the muffler (to the tip out the back of the truck). I realize an aftermarket muffler would be a lot shorter than the stock muffler, so would I have to just get a piece of exhaust tubing to patch the distance? Sorry, might seem like common sense stuff, but I'm young, and stupid, and like to ask questions. Thanks in advance. I dont know what I'd do without you good folk here on dodge forum.
Want a "slight" increase in MPG's and a little more power? Read this,
https://dodgeforum.com/forum/2nd-gen...um-thread.html
If it is all clamped together..... depends on who assembled it. Sometimes, they run those clamps pretty tight, and crimp the pipes. Only way to get those apart without cutting, is a torch. heat 'em up cherry red, and then twist and pull. Without heat, you won't get 'em without cutting them off. Of course, then you could just get a slightly longer pipe to take up the slack of what you cut out.......
Trending Topics
Thanks Hey You, I did my exhaust tonight. Instead of wasting time with the clamps, I just used my sawzall and cut the stock muffler off, installed a thrush glasspack, and ran the piping just before the rear tire. Now I just need to get a tip to finish it off, it sounds so good. Best part was with the muffler, clamps, and extra piping it was only $48 out the door at advance auto. I decided not to use the stock tailpipe and just dumped it early and I think it sounds better that way,
