can i get away with a 2" leveling with stock suspension on an OFF-ROAD
I keep getting different answers, since my truck is lifted 2" all around because i have the OFF-ROAD edition, the nose still has a nose dive, so by putting the 2" leveling, it would be 4" in the front, so can i get away without touching anything else like pitmar arm, control, track bar... Etc
Does the off road version have longer control arms than the regular truck? If it doesn't, you might have to address that as well, else, your front axle will sit too far back.
have it on right now. i don"t believe longer then regular ride height. btw i have overhauled my front end last month. 4ball joints, 4 rod ends, and a right wheel bearing. next week getting the not exactly sure on this spelling, (BDdiesil's 2 inch lifts trac bar.)
now that it is all done. i also have to do the steering stabilizer shock, its shot.
yes it does but the back wont be as high as the front
