Wheel bearing diy?
***none of this applies to a 99, so ignore it.
its all for an 00-01 2wd.
i think? the 99 2wd is the same as the 4wd, with the unitized hub bearing.
i also think? your axle/spindle nut says 'do not reuse'. napa has them.
http://www.pavementsucks.com/tech-article-5.html
read these.
https://dodgeforum.com/forum/2nd-gen...placement.html
https://dodgeforum.com/forum/2nd-gen...aring-nut.html
according to those with 2wd experience, the big nut is either 1-3/8 or 35mm
spindle nut part numbers.
napa has it, under part number BRG 6504007 $10.69
http://www.napaonline.com/Search/Det...007_0297803160
rockauto lists the 2wd nut for about $8 each, with limited supply
calls it... SKF Part # 6504007 {#06504007}
http://www.rockauto.com/catalog/x,ca...,parttype,1616
from another thread out in internet land.
"The 2wd front wheel nut is Dodge part number 6504007. We have plenty on hand. The internet price is $10.32 each plus shipping.
By part number from our website at chryslerjeepdodgeparts.com.
read these.
Yes replacing both inner and outer on both driver and passenger sides. So the bigger bearing (outer?) just goes on the spindle itself with the gasket?
The larger bearing goes into the back side of the hub, and there should also be a grease seal that goes on there as well. (bearing first, then install seal.) Once you have those in place, you can put the rotor/hub onto the spindle, insert the smaller bearing with the smaller diameter end in first, then washer, then nut.
I usually run the nut as tight as I can by hand.... spin the rotor a bit, tighten some more (by hand), and keep doing that until the bearings are fully seated, and I can't turn the nut any more. Then give it an additional eight to quarter turn to preload the bearings just a bit.
There is no such thing as "too much" grease on those.......
Trending Topics
