TCP Performance E-FAN DYI
Old Jul 11, 2011 | 06:39 PM
TheycallmeLaramie's Avatar
TheycallmeLaramie
Default TCP Performance E-FAN DIY
Heres a Link to the writeup that I made for my E-Fan install. Pictures are included. THANKS DODGEFORUM MEMBERS FOR ALL YOUR HELP!!!!!
http://www.sendspace.com/file/k0uazi
Old Jul 11, 2011 | 07:02 PM
Can you post it in a thread??
Old Jul 11, 2011 | 07:17 PM
TheycallmeLaramie
HeyYou! SOOOO DEMANDING :P JUST FOR YOU BUDDY!
  • Unpack box and make sure all equipment on packing list is included
  • Sit out all of your necessary parts and check for damages
  • If painting grind and clean all weld seams
  • Hang and paint aluminum shroud (high heat and optional) – See Below
· Get everything ready to assemble
· Put on both fans with attachment clips FIRST on to FLAT surface and make sure bolts with included washers and lock washers are TIGHT
· Screw on both drivers side and passengers side aluminum flares that hole engine coolant and windshield washer reservoirs
· Screw on SPAL v3 controller and relay for secondary fan as shown below in pictures
· Now you have to remove the old fan. I used a metal File in-between the two screws to hold the clutch while a friend unscrewed the fan assembly see below
· Now after its been removed get your new setup all ready to go move the two reservoir tanks to the sides put the new assembly in (just drop all wires down) and bolt in the four bolts. Re-attach the coolant tanks and your should look like below:
· A/C line gets attached to the positive side of the A/C plug, my switched ignition I ran into the front fuse box and attached onto my cigarette lighter. This is so when I turn the turn off everything turns off. Some people will attach to there battery so when they turn off the fan must get it below a set temp before the fans turned off. Really your choice if you want to hear the fan or not after vs quicker cool down.
· Follow the instructions for the controller Dual OEM fans. Only thing not completely explanatory is the Engine Temperature Sensor. In The Dodge ram it is right behind the thermostat housing. Long needle nose will be able to pull it out so you can hook onto it.
· Last is programming, I held PRG till it blinked amber then hit enter. If you hit enter 1 more time 160 degree thermostat 2 more times 180 3 more 195.You will see the fan light blink the number of the program and then hit PRG to exit.
· Viola! You now have an E-Fan! Thanks to SPAL and TCP Performance and HeyYou! for making this possible!
Old Jul 11, 2011 | 07:19 PM
Thanks. This should be put in the DIY section. Nice write up.
Yeah, I have practiced long and hard to become the *******, post ***** that I am today.
Old Jul 11, 2011 | 08:04 PM
zman17's Avatar
zman17
Retired Moderator - RIP
LOL, you are far from being considered an ******* around here, thats my job! LOL As far as being a post *****, well, that's a subject for a different thread. ....
Oh damn, almost forgot, I agree, this needs to be in the DIY's.
Old Jul 11, 2011 | 09:14 PM
matty675's Avatar
matty675
how much did it run ya?
Old Jul 11, 2011 | 09:41 PM
edlucky1's Avatar
edlucky1
Wow that looks like a good kit. Ive been looking around for a setup that holds both reservoirs and this one is the cleanest ive seen. Nice work!
Old Jul 11, 2011 | 10:08 PM
redneck_ram's Avatar
redneck_ram
he paid 554.95 plus shipping. just checked it on their website.
Old Jul 11, 2011 | 10:57 PM
aim4squirrels's Avatar
aim4squirrels
Mind telling me what that setup set you back? If I have one more fan go out, I'll be switching brands and that looks like a very nice setup.
Old Jul 12, 2011 | 02:45 AM
TheycallmeLaramie
554.95 Parts TCP
35 Shipping to my door
13 high temp engine ram red paint
1 hour cleaning welds with grinder and sanding them smooth
1 hour figuring out how to wire it
4 hours removal, taking pictures, installing
