Cold rough idle, misfires until warm
Well... got the green beast prepped for surgery starting at 7:30 a.m. I can honestly say this is the first time I have ever been happy about seeing oil in the intake manifold. I pulled the TB off... got the trusty flashlight and BOOM... there it was, a nice pool of oil at the back of the intake. Like I said I will be busting into it early and I will let you all know how it goes. Thanks so much for the help on this thing... it has been driving me crazy for YEARS (believe it or not)
This is what I am replacing today. Everything I have read about the sensor points to possible solutions to my problem. I either get the truck fixed or find a for sale sign to put on it. This is a mind boggling problem.
Last night, since the truck hasnt been run much, it threw the CEL. After replacing the Temp Sensor I drove it to the auto parts and had the code run. The truck is running alot better but still has a problem and the CEL says ignition problem so the only ignition parts that have not been replaced are the wires so thats next. BUT... it will wait until after the much needed vacation for the next 6 days.
Vacations over and after replacing the last of the ignition parts (coil and wires) it seems to be running somewhat better but still has the popping back through the exhaust and intake. I have almost replaced everything on the engine with the exception of the cam sensor, map sensor and TPS.
Here is a nice list of replaced parts...
Hughes Plenum Kit
Crank sensor
Cap, rotor, wires, plugs, coil
Pre-cat O2
Coolant temp sensor
I dont think I left anything out but even after all that it still pops through the exhaust and in the intake and runs rough until it gets warm.
Hughes Plenum Kit
Crank sensor
Pre-cat O2
Coolant temp sensor
