46RE Transmission Problem
Old Sep 10, 2011 | 04:44 PM
  #101
zman17's Avatar
zman17
Retired Moderator - RIP
I have to search? Screw that !
Old Sep 10, 2011 | 05:29 PM
  #102
gdstock's Avatar
gdstock
PCMScan. (100 bucks for a license.... )
This one..... (free)
a google search will turn up more of them.... (I want a laptop, so I can actually try out some of these, and have a REAL recommendation....)
Cables are also findable on a google search. Some of the software requires specific cabling, others will work with darn near anything.
Downloaded from the link you provided. I'll check it when cables come in next week and let everyone know what it will do. Simulator was not very "informational" if you know what I mean.
Thanks.
Old Sep 10, 2011 | 05:36 PM
  #103
merc225hp's Avatar
merc225hp
Just a couple of links.
http://www.obdpros.com/index.php
http://www.glmsoftware.com/Default.aspx
http://www.obdpros.com/obd_software.php
Old Sep 10, 2011 | 05:49 PM
  #104
gdstock's Avatar
gdstock
Thanks, I'll check these out.
Old Sep 10, 2011 | 07:43 PM
  #105
aim4squirrels's Avatar
aim4squirrels
Heck, I bet that snap-on cable I have is serial port. Might run it in the laptop and see what happens for grins.
Old Sep 10, 2011 | 11:29 PM
  #106
gdstock's Avatar
gdstock
So as I am thinking I need to replace Governor Pressure Sensor and Solenoid, I decide to double chek kickdown band adjustment and tightened it slightly. Drove about 3 miles, with no change. Except when i got back to the house, I had no reverse.....Could I have screwed up the kickdown band in 3 miles? Would that blow reverse? I plan to put it back where it was tomorrow (daylight because I cannot move it over to get into garage).
If anyone can screw it up....I probably can.
Old Sep 10, 2011 | 11:44 PM
  #107
master tech's Avatar
master tech
Site Moderator & Tech
No that couldn't have screwed up reverse. A broken piston or missing strut will cause no reverse. You could always hook up a 300 psi gauge the reverse port and find out what you line pressure is. Line pressure for reverse goes as high as 220 psi.
Old Sep 10, 2011 | 11:51 PM
  #108
gdstock's Avatar
gdstock
Would that be the strut on front band or rear? When I started this rodeo, I found the anchor for the kickdown band laying loose in the pan, but strut was still in place.
Which piston would it be, and what would cause it to suddenly fail. Transmission just rebuilt, new seals on pistons, and each was inspected thouroughly.
I'll try to round up a gauge and check the pressure.
Old Sep 11, 2011 | 12:01 AM
  #109
drewactual's Avatar
drewactual
I wish you would have said something about that OBD to USB/Serial cable before.. I could have tossed one in the box for you..
the free software linked is as good as any of the pay-for that I've encountered.. I dig it..
getting the computer (tried XPsp3, Vista SP2, and 7sp1) to recognize the port is tricky, and getting it to remember it the next time you slave it up is even trickier..
best of luck with the transmission dude.. I'm all but certain the famed "Pandora's Box" is shaped just like an automatic transmission casing, because of all the mystery it holds.
Old Sep 11, 2011 | 12:07 AM
  #110
gdstock's Avatar
gdstock
Hey, thanks anyway. I have a cable coming and hope it arrives next week. I ahd actually planned to modify it to connect to the computer on my 88 Jag (but maybe not now....seems I got my hands full on this Ram) Also wanted to see what else I could get it to tell me on this Dodge.
