46RE Transmission Problem
Old Sep 11, 2011 | 10:24 PM
  #121
gdstock's Avatar
gdstock
So I got the strut back on the rear band and adjusted per FSM. Filtered ATF through a paint strainer and poured back into quart bottles.
When I was draining and putting the VB into a plastic bag, I noticed that I broke the connector pulling the VB.
I am thinking that super gluue won't help. More $$$$!
Grrrr...
Old Sep 11, 2011 | 10:48 PM
  #122
aim4squirrels's Avatar
aim4squirrels
That connector looks pretty nasty. What's on it?
Old Sep 11, 2011 | 10:55 PM
  #123
gdstock's Avatar
gdstock
Around the O rings is trans gel. The brown coloration on the part that is exposed outside the case is red west texas dirt that did not clean off, with a coat of tans fluid.
Old Sep 11, 2011 | 11:02 PM
  #124
aim4squirrels
Looks like it's inside the connector as well. Perhaps it's for the best, it would suck to button it all up and have that part fail later on.
Old Sep 11, 2011 | 11:14 PM
  #125
gdstock's Avatar
gdstock
I sprayed the inside of the connector with carb cleaner and could not get it clean as I wanted. It is wet in the photo from laying it in the drain pan full of trans fluid also.
New one will be clean....
Old Sep 11, 2011 | 11:32 PM
  #126
master tech's Avatar
master tech
Site Moderator & Tech
Not bad for a transmission tech. Here are some mopar numbers, strut 4471497AB and the connector that is broken is 52118500 that is called a 3/4 shift solenoid.
Old Sep 11, 2011 | 11:38 PM
  #127
gdstock's Avatar
gdstock
Thanks for the part numbers. The strut was good. I think I may have had it installed the wrong way, allowing it to fall out. It was a lttle difficult to reinstall, it kept falling out on the other side when I tried to push the reaction lever against it. Tight spot. Thankfully it didn't do any other damage. Hope they have the connector in stock.
Old Sep 14, 2011 | 10:47 AM
  #128
blackbeasst's Avatar
blackbeasst
im in need of replacing my sensor and solenoid. are those 2 pieces like right there in your face when you drop the pan? if so got any pics of them?
edit: although this is a 48re tranny, is it pretty much the same steps and same pieces and location?
http://www.youtube.com/watch?v=Gb24f8mWCB8
Old Sep 14, 2011 | 11:30 AM
  #129
Yup, beefier parts, but, all pretty much in the same place.
Old Sep 14, 2011 | 05:08 PM
  #130
zman17's Avatar
zman17
Retired Moderator - RIP
Who's is a 48RE tranny?
