46RE Transmission Problem
Old Aug 28, 2011 | 10:13 AM
  #41
MonteC's Avatar
MonteC
You need the frictions for a 48RE, they have the finer splines. Im not sure if you can swap ring gears out or not. I wanna say yes, but im not 100 percent.
Old Aug 28, 2011 | 03:31 PM
  #42
gdstock's Avatar
gdstock
Thanks. I will try to pick them up tomorrow. I don't mind "experimenting" in an area where I am comfortable, but with something like this, I would rather be sure.
Thanks to all of you that have helped. You cannot imagine how helpful you have all been. Without DF, I would not have attemped this task. Can't wait to get this tranny back in and start on other projects like steering, plenum, suspension, and significant body repair! I know I will have more than book value invested, but ther is something about restoring a truck that you cannot put a $ value on sometimes. (Found a 1938 Dodge 1 ton for sale - may snag it up for next project!)
Old Aug 28, 2011 | 09:19 PM
  #43
gdstock's Avatar
gdstock
Default Valve Body
I am installing Sure Cure kit and have a question. I am looking at the separator plate modication on page 4. But there are two plates, niether of them look like the one in the instructions.
Is there something I am missing, or could this be due to a year model difference?
Thanks.
Old Aug 28, 2011 | 09:30 PM
  #44
xjarhead69's Avatar
xjarhead69
turn the plate on the Left 90 degrees clockwise and you will see it.
Dave
Old Aug 28, 2011 | 09:44 PM
  #45
gdstock's Avatar
gdstock
Thumbs up Valave Body plate
I feel a little foolish now. I did not realize that Sonnax was only shoing part of the plate. Between the frustration due to excessive heat, and losing the detent ball, I had decided to give it up for the evening.
Thanks for helping me with this!
Old Aug 28, 2011 | 09:48 PM
  #46
xjarhead69's Avatar
xjarhead69
Your welcome. It happens to all of us.
Sometimes we need fresh eyes.
Dave
Old Aug 29, 2011 | 10:33 PM
  #47
gdstock's Avatar
gdstock
Well, it was a Monday. COuldn't skip out of the office to get frictions. Maybe tomorrow.
I am getting ready to order new TC, but checking various websites, I have discovered that I do not know enough to order it.
Most sites ask for stall speed. Some show 2800 to 3000 rpm. What is factory stall speed for a 46RE, with a 5.2L? Would a higher stall be be better, or worse? (I thought a TC was a TC.)
Old Aug 29, 2011 | 10:43 PM
  #48
aim4squirrels's Avatar
aim4squirrels
Stock is reported to be somewhere between 1800-1900 RPMs. You do not want a higher stall with a stock cam, no real benefit there.
Try precision of new hampton for a stock replacement, should be better then the stock unit with the same general stall.
Old Aug 29, 2011 | 10:55 PM
  #49
gdstock's Avatar
gdstock
Found their website. Guess I gotta find a code on the original. They show several with 23 and 24 splines. Guess I'll count them also.
Thanks.
Old Aug 29, 2011 | 11:16 PM
  #50
gdstock's Avatar
gdstock
Where can I find a converter code. There is a number (3799) stamped on TC housing, a number printed on housing (1289) and a taf with 595 on it. On Precisions's website, I inserted each of these with no luck.
