98 dodge ram 1500 4x4 5.9l running rough
Old Jul 15, 2011 | 02:31 AM
dipndots12's Avatar
dipndots12
Default 98 dodge ram 1500 4x4 5.9l running rough
my 98 dodge ram is running rough it is hard to start and when i am driving and slow down it trys to die and it seemss to be running alittle rich. i cant figure out what is causing this
Old Jul 15, 2011 | 08:29 AM
knoxy's Avatar
knoxy
Yo,
there's a variety of reasons for this you'll find mentioned in the forums.
My truck (same as yours) had similar issues. Replaced my pre-cat O2 sensor and it cleared right up.
A tune up (caps, rotor, plugs, wires) might be in order too.
A clogged cat might not be helping things.
And then there's always the intake plenum....see here:
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Jul 15, 2011 | 11:52 AM
dipndots12's Avatar
dipndots12
i kinda think it might be a clogged cat cause it was running fine then i got in some mud and some mudy water got in the exhaust
Old Jul 15, 2011 | 12:17 PM
blackbeasst's Avatar
blackbeasst
just a heads up about the clogged cat. mine too was clogged (due to probably bad plenum) so i went to a y-pipe with no cat (no emissions here in SC), but my truck is still sluggish. im in the process of collecting all the parts for a plenum replacement.
from what i've read and been told check the plenum first before you replace the o2 or cat. if not you're gonna be back to square one if in fact the plenum is jacked up
Old Jul 15, 2011 | 01:24 PM
dipndots12's Avatar
dipndots12
ok thanks how do you check to see the plenum is messed up
Old Jul 15, 2011 | 01:40 PM
blackbeasst
check out the link in post #2.
Old Jul 15, 2011 | 02:12 PM
dipndots12's Avatar
dipndots12
ok ill check that first
Old Jul 20, 2011 | 04:52 PM
kristina castle's Avatar
kristina castle
I have a 2000 Dodge Dakota 3.9 when the outside air temp is hot the truck misfires and runs rough, when outside temp is cool like at night, it runs fine any suggestions is appreciated.
Old Jul 20, 2011 | 05:52 PM
IAT sensor perhaps?
Old Jul 21, 2011 | 04:13 PM
hydrashocker's Avatar
hydrashocker
I have a2000 dakota 3.9 when it is hot outside it misfires and runs rough at night when its cool it runs fine please help any body
Cross posting in different sections with different trucks with the same issues: https://dodgeforum.com/forum/1st-gen...u-problem.html
