cold air intake
Old Jul 19, 2011 | 10:52 AM
chadhager03's Avatar
chadhager03
Would the spectre or 14x3 give the best gas mileage? And also does the 14x3 get flooded easily? Because I want better gas mileage (10mpg sucks) but I also like going through deep puddles and mud.
Old Jul 19, 2011 | 10:55 AM
blackbeasst's Avatar
blackbeasst
Need to make up the S bolt that holds it in place, but, aside from that, just bolts right on. Also need to deal with the intake hose for the PCV system. Its the one that goes to the bottom of the filter housing.
you mean the hose that feeds air to the intake?
Old Jul 19, 2011 | 12:45 PM
chadhager03
If you google the 14x3 dodge ram there are a lot of forums and DIY about this, I just looked it up and became overwhelmed
Old Jul 19, 2011 | 02:41 PM
The valve side goes from the PCV valve, to the intake. (vacuum source.) The other side, is just an intake for clean air. (don't wanna suck crap into the crank case.) I think dodge swapped sides with the PCV over the years, but, the hose that connects to the aircleaner, after the filter, is the intake side of the PCV system. Valve regulates how much air flows thru the crankcase.
