Old Aug 17, 2015, 12:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problem Guides
Print Wikipost
2001 Dodge RAM Mysterious Oil Leak
Old Jul 18, 2011 | 11:15 AM
lew_miller418's Avatar
lew_miller418
Cool 2001 Dodge RAM Mysterious Oil Leak
Morning all,
I have a 2001 Dodge Ram 1500 5.9, 4x4 with 120K miles on it. Can seem to find a possible oil leak that is happening. I have placed cardboard on the ground nothing. Filter tighten correctly, no drainplug leaks.
So I loose about 3 qts, and not all the time and only when seems like when oil is due to be changed. Not pulling a load or putting any excessive driving, since I drive 180 miles round trip a day.
Any ideas?
Thanks for your help
Lew
Old Jul 18, 2011 | 11:17 AM
Check out the stickied Plenum thread at the top of this forum. Chances are, that is where most of it is going.
Welcome to DF.
Old Jul 18, 2011 | 11:44 AM
lew_miller418
Thank you, will look
Old Jul 18, 2011 | 11:56 AM
poroto07's Avatar
poroto07
hey there
are you from DF maxico city.
I have a problem with my 04 jeep liberty the check engine light is on and appear the code ambient air temperature sensor maltfunctions should i repaced the sensor ?
Somebody have any Ideas
Old Jul 18, 2011 | 02:42 PM
TheycallmeLaramie's Avatar
TheycallmeLaramie
Since you scanned and that's what it says and the sensor is only 25 bucks why wouldn't you get it install it check it and then if it doesnt fix it return the part? You dont need us to tell you that. Start with cheap fixes if its not that then go into more complicated. And since you have a 04 JEEP Liberty I think jeepforum in the 04 liberty section would be more fitting heres the link
http://www.jeepforum.com/forum/f28/
Old Jan 25, 2013 | 03:57 PM
Stuart6789's Avatar
Stuart6789
Red face
Welcome to DF.
I ordered the kit to fix the plenum from hugesengines.com instal went great but the truck won't start after I put it all back together any ides?
Old Jan 25, 2013 | 04:00 PM
stewie01's Avatar
stewie01
Check all the ground connections, checked for pinched wires around where the intake bolts to the motor and check for missed connections.
What all did you replace?
Old Jan 25, 2013 | 04:19 PM
JoshSlash87's Avatar
JoshSlash87
My oil consumption was fixed by changing valve seals,plenum gasket & PCV valve ;-) Now since July I have not used a drop of oil. I was doing a quart every 100 miles by the way lol Problem fixed!
Old Jan 25, 2013 | 06:23 PM
Was yours leaving any evidence of leaks where you parked?
@OP, seems the crank/cam sensor wires like to crawl under the intake when you are bolting it down. I know it's a pain, but, look carefully along the back of the intake for pinched wires, and make sure you hooked up the grounds up by the power steering pump as well.
Old Jan 25, 2013 | 06:26 PM
Wow, this thread has it all....even a Jeep....
