Bad Transfer , possible shiuft fork or vaccume switch?
Old Jul 20, 2011 | 06:45 PM
etdavenport's Avatar
etdavenport
Default Bad Transfer , possible shift fork or vaccume switch?
I was on the road today and my truck suddenly clanked real loud and ground a bit then proceeded to loose all drive capacity. I had to coast to the side. When I tried to put it into park, it make a terrible grinding sound. After playing with the t case shifter for a few moments I got it to catch again and it would go into drive.
I am pretty certain that it is the the shift fork in the tcase, but before I go out and replaced my t-case, I wanted to see if there was a chance that it could be the vacuum switch or something simple like that. I realize that is a long shot, but still. [id rather just buy a $600 reman case than pay a mechanic $400 to fix the old one]
thanks!
Old Jul 20, 2011 | 09:00 PM
Vacuum switch will not give you those symptoms...... an output shaft snap ring that has been broken for a while will though...... If it made expensive noises..... and is you only driver.... verify the t-case is bad, and if it is, replace it.
Old Jul 20, 2011 | 09:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
"terrible grinding sound", TC is toast.
Old Jul 21, 2011 | 12:16 AM
etdavenport
I got it into 4 low and was able to drive it home, 15 miles at 30mph....lol but it will not go in or out of anything else, and despite being in 4 low, the front drive shat isnt turning...re-manned t-case here I come... I needed an indexing ring anyway to fix the extreme angles on my drive line.. This truck is turning out to be a load of fun....
My ABS and brake light are still on too even after replacing both the sensor on the diff and the gears [abs ring was missing teeth when I had 4.56's installed. Pinion and ring were missing teeth also...]
Old Jul 21, 2011 | 10:20 AM
Need to get the ABS codes read, and see what it is whining about. Might be as simple as the brake switch. (at the pedal.)
Sounds like a good excuse for an upgrade.
