Krc 210x cam?
Old Jul 23, 2011 | 12:55 PM
Most of the dyno charts I have seen don't even start until 2K....... however, we have a fair few members here that run the hughes intake, and they didn't have any complaints about low end loss..... You would definitely pick up some upper rpm power with the better manifold though..... the kegger just isn't designed for much above 4500 rpm.
Old Jul 23, 2011 | 01:13 PM
sinus19's Avatar
sinus19
Originally Posted by DodgeRam5.9
Sorry I didn't already mention this but I have upgraded to Hughes valve springs rated for .600 lift and upgraded the retainers. I also have 4.11 gears on 31inch tires. And I have the Hughes shaft mounted adjustable roller rockers so the different base circle of the cam is not a problem for me. I'm still kind of interested in the cam but the fact that it doesent really kick in until 2600rpm is kind of scary for towing. Would the hughes air gap intake give me some more top end without sacrificing all my low end torque?
I got an FI Airgap from Hughes and i really didn't notice any difference in the low end. but i did notice a big difference in the mids and high.
Old Jul 23, 2011 | 05:38 PM
trucklover's Avatar
trucklover
Originally Posted by 4085spd
Stock cam need's gear's. Plus your running large valve heads with a small cam.
This cam also needs a stall matched to your vehicle.
Old Jul 24, 2011 | 06:59 AM
Carl2206's Avatar
Carl2206
heres a few graphs of the 604 or krc 210 cam. showing 300ft torque at 2k way low with a M1. keep a kegger on expect those torque numbers to go up. lower the Lsa to 110(210x) would move the torque curve little lower in the rpms. 210x would be a torque monster way down low.
http://www.dakotart.com/forum/showthread.php?t=868
http://www.dakotart.com/forum/showthread.php?t=272
Old Jul 24, 2011 | 11:01 AM
CPTAFW163's Avatar
CPTAFW163
KRC has an RV cam. PM b1llyW (former owner of KRC before he sold the company) on this site or bionicdodge and he will hook you up with Comp cams to get the specs of the RV cam to them. Comp is who grinds his cams.
Here is some info about the RV cam and some other bolt ons. More torque than a hemo and 20 HP short of the hemi (rear wheel dyne numbers).
READ THIS: It is called "Torque is a good thing"
http://www.bionicdodge.com/bionic/in...p?topic=9197.0
200/206 .408/.408 (He used 1.6 RRs, if you get 1.7 it changes the geometry of the cam and may actually hurt the numbers). All he did was use stock RT heads and some other used parts (Roller rockers). Plus an underdrive pulley. He said he was running 3.55 gears and LOVING it.
