Irratic idle in overdrive
Old Jul 24, 2011 | 12:50 PM
chad samenko's Avatar
chad samenko
Default Irratic idle in overdrive
2000 dodge 2500gas 5.9 idle jumps 100-300 rpms when in overdrive going down highway on slight grade some times in 3rd its an automatic, please help
Old Jul 24, 2011 | 03:16 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Jul 24, 2011 | 03:33 PM
Ramzy's Avatar
Ramzy
Had the same issue. I had to replace my TPS. Easy and cheap fix.
Old Jul 24, 2011 | 04:00 PM
aim4squirrels's Avatar
aim4squirrels
You cannot idle in overdrive.
Are you speaking of a fluctuation in cruising speed while in overdrive?
Old Jul 24, 2011 | 04:15 PM
Ramzy's Avatar
Ramzy
Think he is talking about a momentary increase in RPM while cruising.
Old Jul 24, 2011 | 04:29 PM
newman1367's Avatar
newman1367
Yep, TPS. About 30 bucks and 2 screws, located on the driver side throttle body.
Old Jul 25, 2011 | 01:12 PM
chad samenko
Yes it is a momentary fluctuation in rpms's at cruising speed, the speed does not change, you can hardly feel it but you can hear it in the exaust. 100-300 rpms. changed tps, cleaned tb, adjusted tv cable, new plugs, new wires, new dist cap and rotary button, replace tran fluid and filter.
Old Jul 25, 2011 | 01:13 PM
Check the electrical connections at the trans, might just be a bad connection there... May also be a failing TCC solenoid.
Old Jul 25, 2011 | 07:23 PM
chad samenko
dont mean to sound stupid but what is the tcc solenoid, is it in the trany
Old Jul 25, 2011 | 09:05 PM
CPTAFW163's Avatar
CPTAFW163
What they all said. My 1996 did the same thing. It doesn't hurt anything.
Make sure that you get a factory TPS from the dealership. Sometimes the cheap aftermarket sensors from napa/autozone are just as bad as a broken stock part.
