hi i just bought a 2001 dodge ram1500 quad cab 4x4 i paid 5400 with 140,000 miles the truck had quite a few problems fixed most of them now my main problem is the truck idle the idle changes from real quite to real loud also theres a real loud hissing noise and when i attept to drive it goin down the road it bogs real bad, ive talked to many mechanics and there all clueless, i put new plugs,belt,air filter,o2 sensor,main computer, fixed booster cable leak,and couple other cracked tubes,also fixed evap system large leak,now my check engine light is back on saying a different o2 sensor is bad havent fixed yet, this truck has been basicly sitting since i bought it 5400 wasted. CAN ANYONE HELP ME WITH THIS
The engine is a 5.2. I checked every hose and replaced every one that was bad and still the problem persists, it also it isn't a constant bogging which makes me believe it's not a vaccum leak anymore.
