Oil Pump Question
Old Jul 28, 2011 | 03:46 PM
Carl2206's Avatar
Carl2206
Originally Posted by ClubCab5.9
Let's see some picture's of this MEGA VIPER3 trans in your garage? .....Picture's of the old vs new POST EM UP LET'S SEE THEM.
HV pump WILL require you to swap out the oil pump shaft.
http://www.summitracing.com/parts/MEL-IS-72/
X2 on both. Not every day someone says they hv a mega viper3. Hook us all up with some pic's with install.
Old Jul 28, 2011 | 06:36 PM
dhvaughan's Avatar
dhvaughan
yes you should replace the pump.
yes you should use the hi-vol.
i cheaped out on mine and ended up with slightly lower oil pressure than i originally had.
pay attention to the details on the rear main. there is an inside and outside which are different. don't get it backwards.
and congrats on the PATC.
Old Jul 28, 2011 | 07:01 PM
Hahns5.2's Avatar
Hahns5.2
Originally Posted by BigRedRam95
does a high volume pump just move more volume of oil faster? I have been told that it can pump so fast it sucks the pan dry before the oil can make its was back down the motor. Could we not just put a high pressure pump on instead of a HV pump?
Pressure=resistance to flow. Increase flow with the same resistance and you will create more pressure.
Old Jul 28, 2011 | 10:16 PM
heyblue46's Avatar
heyblue46
Thanks everyone for the opinions. I'm still not really sure whether to go with the standard or the HV. I will try to get some pics posted tomorrow.
Steve
Old Jul 28, 2011 | 10:26 PM
How many miles on your truck?
Old Jul 28, 2011 | 10:42 PM
aim4squirrels's Avatar
aim4squirrels
I can only speak for me and mine.
I've had the melling HV pump in mine since 65,000 miles. It currently has 112,500 miles.
I did not use a hardened shaft. I just changed the camshaft last week and had the drive gear out, there was no wear.
I have a stock depth pan. I use 10w30 oil, and I fill it to the tip top. I have done about 50 wot runs up to 5200 rpms. I have never drained the sump to my knowledge, or the oil gauge's. I think this happens to guys that don't run their truck to operating temperature before driving at WOT.
Maybe I'm just lucky. Maybe you won't be, who knows.
Old Jul 29, 2011 | 10:14 AM
heyblue46's Avatar
heyblue46
around 170k
Old Jul 29, 2011 | 10:40 AM
GO with the high volume pump then.
