engine trouble need help!
Old Jul 31, 2011 | 01:39 PM
  #61
DodgeRam5.9's Avatar
DodgeRam5.9
Ok I'll try that now
Old Jul 31, 2011 | 01:46 PM
  #62
DodgeRam5.9
Same exact thing it has only dine this now since I cleaned the injectors and throttle body up it certainly sounds like it's missing but the scanner says it is not
Old Jul 31, 2011 | 01:49 PM
  #63
Not just the lumpy cam is it? If you give it a bit of gas, just to raise the idle a bit, does it smooth out?
Did the codes reset? Will it idle on its own?
Old Jul 31, 2011 | 02:04 PM
  #64
DodgeRam5.9
It's not the cam it just started sounded like a miss since I cleaned everything, now I'm not sure what I did I just unplugged the connecter On the iac and it idles fine now so it could have just been something weird. Now since I have reset the PCM the code came on for high voltage on the number 2 injector I unplugged all the injectors with the iac unhooked and had no drop in idle at all as well
Old Jul 31, 2011 | 02:40 PM
  #65
Try the same test, but, instead of disconnecting injectors, pull the plug wires off. (IAC still disabled.)
Old Jul 31, 2011 | 03:14 PM
  #66
DodgeRam5.9
What exactly would that test
Old Jul 31, 2011 | 03:16 PM
  #67
If you get an RPM drop when you disable a cylinder..... More for my curiosity than anything else.... of course, if you don't get a noticeable drop when doing that... then there is something else going on that we are missing.
What is your truck idling at while testing?
Old Jul 31, 2011 | 03:20 PM
  #68
DodgeRam5.9
Right around 800rpm I'll try it. Cant hurt
Old Jul 31, 2011 | 03:23 PM
  #69
Can you get that any lower? If you could get it down to 600, or even less..... it might make an rpm drop more noticeable.....
Old Jul 31, 2011 | 04:35 PM
  #70
DodgeRam5.9
I let it warm up good to make sure it was off the high idle and tried unplugging the wires and I could hear a drop still hard to notice for sure when I unplug the injectors but now that it idled down lower it sounds like the rpm does drop. The scanner is telling me that the throttle position is at 100% at idle and it keeps throwing the TPS code it only started this since I cleaned up the throttle body
