still transmission problems
Old Jul 29, 2011 | 06:01 PM
king_moaoe's Avatar
king_moaoe
Default still transmission problems
well i recently found a leak from my dipstick grommet (fixed it) my friend filled the tranny with ATF+4 but he over filled by one bottle, could this casue problems? also i get going and now my engine or something is making a rattling sound only when i touch the gas. the tranny also stays at about 3000 rpm instead of the 1500 rpm it was before the problem. any ideas. also looking for a good place to buy a engine and tranny for pretty cheap that either deleivers or is close to utah (only if tranny keeps going)
Old Jul 29, 2011 | 06:07 PM
I quart over full might be a bit much. Check the fluid after driving the truck for a bit, and if it is foamy..... you need to get some of the excess out of there. MonteC (our resident trans guru here.....) suggests that a bit over full is actually a good thing, but, not to the point of the fluid getting air whipped into it.
Sounds like you are missing O/D, and TCC engagement...... or, you have overdrive turned off?
Old Jul 29, 2011 | 06:10 PM
king_moaoe's Avatar
king_moaoe
i checked and overdrive is on
Old Jul 29, 2011 | 06:15 PM
Then somethin' ain't right..... take it somewhere that you have a nice stretch of road, with very little traffic..... From a dead stop, accelerate slowly, and pay close attention to what shifts you get. You should see a drop on the 1-2 shift, another drop on the 2-3 shift, a significant drop on the 3-4 shift, and a little drop when TCC engages. See which ones you get, and let us know.
Is the CEL on by any chance? Trans temp lite??
Old Jul 29, 2011 | 09:23 PM
MonteC's Avatar
MonteC
The torque converter will lock up before O/D if you accelerate slowly.
I would put a scan tool on the truck before condemning anything. Might be something simple. Maybe the computer is seeing something wrong and not allowing o/d.
Old Jul 29, 2011 | 09:28 PM
king_moaoe's Avatar
king_moaoe
would autozone have a computer i need?
Old Jul 30, 2011 | 10:01 PM
king_moaoe's Avatar
king_moaoe
alright update. my over drive is not working. autozone won't check unless a light is on. i read in my manual if the transmission get too hot the over drive will be disengaged. but now it is not reactivating, how can i fix that? the transmission got really hot when it was leaking and starting smelling like it was burning but once i fixed leak and had it refilled it went away.
Old Jul 30, 2011 | 10:03 PM
Does the O/D Off lite stay on? Do you get TCC engage?
Old Jul 30, 2011 | 10:06 PM
king_moaoe's Avatar
king_moaoe
o/d lite stays on, but it made no difference if on or off. im not going to lie i don't know what tcc is.
Old Jul 30, 2011 | 10:07 PM
Torque converter clutch. Makes for a direct mechanical conection between engine, and trans, instead of the usual fluid coupling.
If the O/D Off lite is staying on, you may still have some issues...... not getting a CEL I take it? (check engine lite.)
