lifting options
Old Jul 30, 2011 | 10:05 PM
5 inches is generally enough to fit 35's. I don't know if the O/R edition got any axle trussing, so, that may be as large as you want to go. If they are going to rub, it will be on the lower control arms of the front suspension. Slightly lower backspacing on the wheels would fix that, or, just don't turn that sharp.
Old Jul 30, 2011 | 10:10 PM
BigRedRam95's Avatar
BigRedRam95
this is what I want my truck to look like 3 inch suspension and 3 inch body on 33s I might go with 35s. I have all of it I just need to put it on.
Old Jul 30, 2011 | 10:11 PM
dairyfarmboy's Avatar
dairyfarmboy
yea 5 inches of lift plus 35s should be tall enough im 6,3 and dont like having to go down to get into veehicles i want to go up lol
Old Jul 30, 2011 | 10:14 PM
BigRedRam95
The offroad edition had trussing
Old Jul 30, 2011 | 10:42 PM
Noted. Thank You.
Old Jul 30, 2011 | 10:50 PM
FatDodge's Avatar
FatDodge
I think this was debated before... but, once you get over 3" of lift, (and you are already starting with 2.....) you need to address the front control arms as well. I don't know if the Off Road edition trucks came with longer control arms than the non-OR trucks.....
Once you get over that magic number 3, lifts start getting expensive.....
pitman arm, sway bar, brake lines (if u wanna do it right), shocks, etc ...also the cost of an alignment
Old Jul 31, 2011 | 01:43 PM
dairyfarmboy
anyone have pictures of one that would have 1 inch coil spacers up front and 3 inch body lift´
