Fuel Pump Replacement
Old 08-01-2011, 12:48 PM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
Loosen up the bed bolts and take out the ones on the drivers side, leave the passenger side ones in but loose
Now take a piece of 2x4 or pipe whatever you have laying around thats long enough and prop the drivers side of the bed up, will give plenty of room and you dont need a couple more hands.
This will take no more than 15 minutes with a decent impact
Agreed fuel line disconnect should be 3/8's in most metal kits that are color coded its the gold one.
Old 08-02-2011, 09:08 AM
qlty94's Avatar
qlty94
qlty94 is offline
Good info by read head hunter on leaving passenger side bolts in and only loose that should also eliminate having to align the bed bolting it back.I'm gonna try that when I replace my rusted fuel line assembly.Thanks for the TIP.
Quick Reply: Fuel Pump Replacement
