ABS not working?
Old Aug 10, 2011 | 11:39 AM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Indexing is not for that style. The style with a shaft and gear on it get indexed. You have the ABS issue, which has nothing to do with that sensor. The rear one needs to be replaced first and eliminate that problem.
Old Aug 10, 2011 | 12:15 PM
  #22
There should be index marks, with numbers, on the body of the sensor housing. Need to know what the tooth count on the driven gear (the one in the sensor) is, and then look for the index mark with that number next to it, and that's the one you use.
There are some good pics, and a better explanation in the 96 service manual you can download from here.
Old Aug 10, 2011 | 12:32 PM
  #23
zman17's Avatar
zman17
Not if he has a gear like the one in his pic. As a matter of fact, if he does have one like in the pic, according to PATC it's a 241 TC. Which would be odd in a 1500.
Old Aug 10, 2011 | 12:42 PM
  #24
Shouldn't matter which t-case he has, they all used the same sensor, and the alignment procedure in the the manual doesn't differentiate between any of the versions.
Old Aug 10, 2011 | 12:46 PM
  #25
zman17's Avatar
zman17
They might use the same sensor but not the same gear.
Old Aug 10, 2011 | 01:15 PM
  #26
Stoft's Avatar
Stoft
This is how my sensor looks like,
And this is how the "wheel" looks like on the axle,
Old Aug 10, 2011 | 01:20 PM
  #27
Stoft's Avatar
Stoft
Shouldnīt it be just to stick down the sensor and then drive?
Old Aug 10, 2011 | 01:22 PM
  #28
zman17's Avatar
zman17
The first pic is the part that get's indexed as HeyYou said So he's obviously right about that. The other part just goes on one way.
Also it's pretty obvious that the patc website is wrong in stating that the one in the second pic is for a 241 tc.
Old Aug 10, 2011 | 01:24 PM
  #29
Stoft's Avatar
Stoft
Ok, must figure out how to do that "indexing".. Hard to understand when you are from Sweden.. LOL
Old Aug 10, 2011 | 01:26 PM
  #30
zman17's Avatar
zman17
Download the 96 service manual from the FAQ section or get a Haynes manual, the procedure is in there too.
