help, wont start
Old Aug 8, 2011 | 09:42 PM
It cranks, but won't fire? Are you getting spark?
Old Aug 8, 2011 | 11:28 PM
chadwall's Avatar
chadwall
Played with relays. Swapped them and put back. Then I floored it and got it started. But it won't idle now, above 1k rpm it seemed fine. But below that and it dies.
Old Aug 8, 2011 | 11:32 PM
TPS or IAC.... You could try cleaning the throttle body, and IAC passages therein..... might fix it. If it doesn't, check the tps with a meter.
Old Aug 8, 2011 | 11:52 PM
chadwall's Avatar
chadwall
Where is the tps, and how do I check it? Why would that prevent it from starting, normally I don't have to give it any throttle to start.
Old Aug 9, 2011 | 08:07 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Most likely the IAC on back of TB. I'd do like HeyYou suggested and remove and clean the TB .
Old Aug 9, 2011 | 10:23 AM
chadwall's Avatar
chadwall
All right ill give it a shot.
Old Aug 9, 2011 | 10:39 AM
zman17's Avatar
zman17
Get a TB gasket for 3 or 4 bucks too. And while it's off, get a mirror and look around inside the manifold for oil pooling.
Old Aug 9, 2011 | 10:52 AM
chadwall's Avatar
chadwall
Will do on the gasket and checking for oil.
What is an iac and tps, where are they located, and what do they look like?
Old Aug 9, 2011 | 10:53 AM
chadwall's Avatar
chadwall
And is the throttle body hard to remove?
Old Aug 9, 2011 | 10:58 AM
zman17's Avatar
zman17
TB is easy to remove, 4bolts and some linkage. The IAC is on back of the TB. TPS is on driver side of TB. (can't be cleaned) The IAC can be. But don't push/pull or twist the pintle. SPray it and let it dry. BTW, remove the negative battery cable before doing anything.
Clean the bore out good in the back of the TB where the IAC inserts into, and don't lose the oring.
