help, wont start
Old Aug 8, 2011 | 07:48 PM
chadwall's Avatar
chadwall
Default help, wont start
All of a sudden my truck won't start. My battery was dead this morn, charged it, and it cranks, but won't fire. Even sprayed some starting fluid and no go.
All fuses have power except the oxygen sensor one under hood. Changed fuse and still nothin on it.
I recently removed a six disc changer from under the seat. And clipped and capped the wires that were supplying it power. Drove it after that. Then had some hell of a couple rain storms.
Any ideas?
1999 1500 5.2
Old Aug 8, 2011 | 07:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You hear the fuel pump running?
Old Aug 8, 2011 | 07:57 PM
chadwall's Avatar
chadwall
Yes, it hummer when I turn to start. I think its gotta be electrical cause the battery drained, and won't fire with ether.
Old Aug 8, 2011 | 08:05 PM
zman17's Avatar
zman17
Try swapping the ASD relay with the horn relay. And check ALL the fuses with an ohm meter, not just by eye.
Old Aug 8, 2011 | 08:11 PM
chadwall's Avatar
chadwall
Will do. Then ill report back. I used a test light.
Old Aug 8, 2011 | 08:15 PM
zman17's Avatar
zman17
make sure the battery is fully charged also. Maybe even get it tested. These rigs don't like to run if the battery isn't up to snuff.
Old Aug 8, 2011 | 08:17 PM
chadwall's Avatar
chadwall
Ya, just charged it. Original battery...
Old Aug 8, 2011 | 08:26 PM
zman17's Avatar
zman17
You try holding the pedal down when starting?
Old Aug 8, 2011 | 08:30 PM
JackJ's Avatar
JackJ
Get the battery tested, if it is bad then it won't hold a charge. Try starting with a jump box if you have one.
Old Aug 8, 2011 | 09:38 PM
chadwall's Avatar
chadwall
Yes, pedal down, half down, battery is good and tried with charger hooked up in jump mode too.
