Old Aug 5, 2015, 12:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
Transfer case saver install tomorrow
Old Aug 14, 2011 | 06:28 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Nothing wrong with preventative maintenance. Explain the problem you are having with the knock in more detail, and my DF friends and I will be more than happy to help diagnose it.
Old Aug 14, 2011 | 08:01 PM
  #22
chadhager03's Avatar
chadhager03
Well I don't seem to be having the low speed knock in 4wd. But the problem I'm having is when I'm driving in first and accelerating steadily up to 2000 Rpms, when I let go of the gas it shifts into second and knocks. I can video tape it if you would like a better explanation. Thanks
Old Aug 14, 2011 | 08:40 PM
  #23
that's just driveline slop, and is pretty normal in a 4wd vehicle. If you just hold steady pressure on the gas, does it do it as well?
Old Aug 15, 2011 | 12:02 AM
  #24
DodgeRam10's Avatar
DodgeRam10
i have the same issue, if i let off the gas around the time it shifts it clunks pretty loud, but ive noticed if i stay on the gas till after it shifts to 2nd and then slowly let off the gas it wont clunk. i was wondering if it was the t case snap ring or not but it does sound like the driveline or for some reason i think of the torque converter when i hear it, does the t converter have any play?
Old Aug 15, 2011 | 01:46 AM
  #25
chadhager03
Ya I could move it when I was tightening down the bolts. I figured it was the 4wd and it does not knock holding the throttle steady
