front outer axle seal
Old 08-17-2011, 07:18 PM
squarebit's Avatar
squarebit
squarebit is offline
Default front outer axle seal
Seems I got the wrong part from Napa when I was explaining it, and the FSM makes no mention of this thing's existence... but what the hell is the VERY outer seal (right behind the u-joint) called?
Does it even exist? All I found where shards of what appeared to be an old seal/dust cover.
Can it be found on Napa's website?
Old 08-17-2011, 07:21 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,388 Likes on 3,128 Posts
It's just a dust shield. Not really all that useful, as it tends to trap stuff IN the axle..... I wouldn't even worry about it.
Old 08-17-2011, 07:52 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
I believe this is what you want, National part# 5778. Or go to Quad4x4.com. http://quad4x4.com/Dodge%20Frt%20Axle&Steering.htm
BTW, it would be nice of you to put all the info about your truck into your sig.
Old 08-17-2011, 09:23 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
its also called a "slinger".
i also recommend you NOT put it in, as it traps mud in, rather than allowing it to wash out. the actual seal is at the inner end of the tube. the slinger is useless.
here's a pic. this site is pretty expensive. if you're set on replacing it, look elsewhere for better pricing.
http://www.riversidegear.com/4x4-fro...94---2001.html
Old 08-17-2011, 09:40 PM
dhvaughan's Avatar
dhvaughan
i'm going to disagree on National 5778 as the slinger. i see that as the pinion seal.
http://www.superioraxlegear.com/seal...8-p-15180.html
Old 08-17-2011, 10:15 PM
squarebit's Avatar
squarebit
https://napaonline.com/Catalog/Catal...+50022+2022009
That's a pinion seal. It sort of looks like some of the pieces I found, but not really like what's on the other side.
Is it really that important then? To be clear, it is the very last "seal" on the axle tube.
It's for a dana 44 on my 1500 btw.
edit:
Outboard Axle Shaft to Axle Housing Seals looks more like it. Replace or screw it?
Old 08-17-2011, 11:35 PM
HeyYou is offline
screw it.
Old 08-18-2011, 01:19 AM
chadwall's Avatar
chadwall
chadwall is offline
I had hell finding one too when I did my u joint. On phone now, but ill get the website I got mine from tomorrow, $13 I think.
Old 08-18-2011, 01:21 AM
chadwall's Avatar
chadwall
chadwall is offline
Dealership didn't have it, would have to order entire axle assembly to get from them. The last link from squarebit was it.
Old 08-18-2011, 06:51 AM
zman17's Avatar
zman17
zman17 is offline
Listed on Rock Auto, NATIONAL Part # 5778 More Information About this Part Oil Seal; Polyacrylate Seal, Shaft Size=1.552", Housing Bore=3.16, Outer Diameter=3.165, Width=0.53in
Front Axle; Outer; Spicer 44-3F 8.5" R.G.
Quick Reply: front outer axle seal
