CEL Tansmission?
Old Aug 20, 2011 | 12:45 AM
badrhino's Avatar
badrhino
Default CEL Tansmission?
I have a 1995 Dodge Ram 1500 w/ 318 Automatic and the CEL comes on every time I put the vehicle in motion. What can be causing this? I can't find anyone that has the right connection to read the codes but I know it has something to do with the transmission as it started shifting a little funny after the light started coming on.
Old Aug 20, 2011 | 01:23 AM
does your speedo work? abs lite on as well? brake lite?
Welcome to DF!
Old Aug 20, 2011 | 02:36 AM
jasonw's Avatar
jasonw
Site Moderator
No auto parts stores in your area have OBD I readers? They will usually read your codes for free.
Old Aug 20, 2011 | 06:26 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Try this, http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Old Aug 20, 2011 | 01:44 PM
badrhino's Avatar
badrhino
Advanced doesn't have one that fits, and O'Reilly people are a bunch of morons. There's fits but they can't get it to work.
Originally Posted by zman17
Thanks!
I will try this out.
Old Aug 24, 2011 | 07:03 PM
badrhino's Avatar
badrhino
Found
Code 32- EGR Solenoid circuit Short or open in the EGR solenoid circuit. Check for loose, broken, or shorted wire in the EGR valve wiring and connectors. Possible air fuel ratio imbalance not detected during diagnosis.
Code 37-Torque converter clutch solenoid CKT or Trans temp sensor too high or low
Any suggestions?
Old Aug 24, 2011 | 07:27 PM
Check the wiring on both circuits. If the wiring looks ok, gonna have to replace parts.
Old Aug 24, 2011 | 11:11 PM
badrhino's Avatar
badrhino
I tried to find the damn EGR valve and am having trouble locating it. Where is it?
I still think it has to do with the transmission as the light don't come on until you drive for a bit. (Three Part Question)What do I check on the tranny... Is there a diagram of where these parts I need to check are located or and are they simple to get to?
Old Aug 25, 2011 | 08:28 AM
You can grab the 95 service manual from the faq section. That will have all the wiring diagrams.
EGR valve is behind the intake manifold, on the passenger side. (yeah, cleverly concealed....)
Check all connectors for corrosion, broken/exposed wires, all the usual stuff.
Old Oct 15, 2011 | 11:44 PM
badrhino's Avatar
badrhino
How do you get to that damn thing? It is back there with very little room.
