New Lower Ball Joint nuts won't tighten!
Old Aug 20, 2011 | 04:14 PM
skydog's Avatar
skydog
Default New Lower Ball Joint nuts won't tighten!
New Moog ball joints , lower. 4WD. Fit the knuckle back on. The lower ball joint nut is a lock nut, once it gets a little tight on the threads the ball joint stud just spins. Can tighten it. I tried tightening the top joint first to move the knuckle higher, but it still doesn't work. Is the the knuckle is worn? It seems that the taper isn't tight in the knuckle.
Old Aug 20, 2011 | 04:29 PM
Run the top nut all the way tight, that 'should' stop the lower from spinning, if you have air tools, hit it with an impact wrench, once it tightens up a bit, it will stop spinning.
Old Aug 20, 2011 | 04:34 PM
skydog's Avatar
skydog
I torqued the top one over 80 ft lbs and it still spun. Moog calls for 75 on the top I think...didn't want to stretch the top hole.
Old Aug 20, 2011 | 04:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can also get the rest of it put back together, including the wheel. Drop the jack and you'll be able to tighten it .
Old Aug 20, 2011 | 04:37 PM
skydog's Avatar
skydog
Have you heard of this happening before?
Old Aug 20, 2011 | 04:41 PM
zman17's Avatar
zman17
Yea, that's how we know how to tighten it. LOL
Old Aug 21, 2011 | 06:54 PM
skydog's Avatar
skydog
Worked like a charm! Thanks ZMan! GO PATRIOTS!!!
Old Aug 21, 2011 | 07:10 PM
zman17's Avatar
zman17
Go Patriots? In that case, Too bad it worked, I wish you had more prob with the ball joints. LOL
