plenum done still running crappy
Old Aug 22, 2011 | 11:11 PM
sullivanj04's Avatar
sullivanj04
Default plenum done still running crappy
So just got the plenum fixed and it needed it their was a crap load of oil in there fired it up and still will barely iddl it does better when under throttle but still doesn't feel right so next all new plugs no change I notice it smells like its running ritch no smoke good oil pressure not overheating and now im stuck and tired of throwing parts at it ia there any cheap easy ways to narrow down my option and be able to test individual components
thanks
Old Aug 22, 2011 | 11:52 PM
matt72991's Avatar
matt72991
i would try and o2 sensor. with a bad plenum the oil will ruin the o2 readings and can cause the truck to run like ***.
Old Aug 22, 2011 | 11:56 PM
sullivanj04
Should I check the one right before the cat is there an easy way to test it or do I just have to throw in a new one
Old Aug 23, 2011 | 07:04 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Get a new NTK o2 from rock auto. And did you clean the TB when you had it apart. The IAC and bore on the back of it in particular?
Old Aug 23, 2011 | 07:09 AM
Novarider's Avatar
Novarider
Also the cat can get clogged from the oil that came from the bad plenum
Old Aug 23, 2011 | 09:37 AM
lastrights's Avatar
lastrights
Seafood might do good for carbon build up on heads
Old Aug 23, 2011 | 09:39 AM
LOLOL
That would be SeaFOAM. I could just see someone dropping fried shrimp down the throttle body.
Old Aug 23, 2011 | 09:50 AM
xjarhead69's Avatar
xjarhead69
LOLOL
LMAO!! I like shrimp cocktail, not fried.
Dave
Old Aug 23, 2011 | 10:01 AM
Yeah, but, what does the TRUCK like?
Old Aug 23, 2011 | 10:12 AM
xjarhead69's Avatar
xjarhead69
Im sure if it will run then it prefers fried. LOL
Dave
